Temperature controls are flashing on display
Old May 15, 2017 | 01:58 PM
Rrjr0208's Avatar
Rrjr0208
1st Gear
Default Temperature controls are flashing on display
The temperature controls are not working and start to flash when starting the car?
Old May 15, 2017 | 08:04 PM
RicK T's Avatar
RicK T
If you are talking about the HVAC unit below the radio, a flashing display is usually just the first sign of a dying unit. You can replace before it fails completely or wait until it does fail. One problem is, if you wait, will your dealer have a replacement in stock or will you have to wait a week or more and have to live without A/C while they order the new unit?
New ones are "about" or "in the range of" $400 - $450. New and used units can be found on ebay or the Parts For Sale section here from about $200. Most owners who have some mechanical ability can replace it themselves.
Old May 15, 2017 | 11:35 PM
HOXXOH's Avatar
HOXXOH
Mine did that 5 years ago this month. I did a 24 hour battery disconnect and it hasn't had a problem since then. I'm certainly not saying that's a cure, but it sure won't hurt to try it.
Old May 16, 2017 | 06:46 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
I had mine go out last September on my 13 GS. We were 1,000 miles from home. On the return trip it started working once and thankfully it was out again when I took it to the dealer. It was replaced under 3/36 warranty with 3 months left on the warranty.
Old May 17, 2017 | 10:45 AM
Unreal's Avatar
Unreal
Same thing. Died completely shortly after.
Found a used one on here, been fine for ~2 years now. Fairly common issue.
Old May 17, 2017 | 12:53 PM
DrivnXcitment's Avatar
DrivnXcitment
Mine is an 05 and has been doing it off and on now for around 4 years. I'm just too cheap to spend the $400 for a head unit. But knowing there are some used ones out there I'll have to check those out too.
The purpose of my reply is to say it's not a great big deal, just more of an annoyance until the unit finally dies.
Old May 20, 2017 | 08:01 PM
BROCKYJACK's Avatar
BROCKYJACK
Mine started that three years ago and had it replaced at 20k miles under warranty in May of 2014. Got in it Thursday to go to the store and it was flashing. Damn it man!!!!
To Temperature controls are flashing on display
