New tires???
Old May 31, 2017 | 04:18 PM
garydinapoli's Avatar
garydinapoli
Default New tires???
Hi, I have a 2010 grand sport with newer run flats, Im sick of the road noise and ruff ride... Has anyone switched to something else and are happy with it???
THANKS IN ADVANCE !!!!
Old May 31, 2017 | 05:18 PM
Homer3D's Avatar
Homer3D
Dupe post.
https://www.corvetteforum.com/forums...y-2010-gs.html
Old May 31, 2017 | 07:55 PM
jrose7004's Avatar
jrose7004
Nope, nobody has ever changed tires on a Corvette!
Old May 31, 2017 | 09:14 PM
Not So Fast's Avatar
Not So Fast
, Hankook Evo2 for me, totally satisfied in all depts.
NSF
Old May 31, 2017 | 10:33 PM
mikeCsix's Avatar
mikeCsix
Sincerely Gary, welcome to the forum. As stated earlier, there are literally tons of threads on tires with opinions all over the place as to what is best.
You say your GS rides rough, are you the second owner? If so, the previous owner may have changed the shocks and you may be riding on something a little more aggressive. The OEM GS shocks are GS specific and actually make the car ride pretty nice. The Z06 sway bars help to keep cornering flat and help to get a little more out of the wider than base model tires. You might try to get some part numbers off of the shocks and look them up.
The tires, if OEM, are Good Year Supercar tires. They are better than the ones on the base model and don't suffer from some of the maladies you might read about. I have found the GS can hit over a G in turns on a good wheel alignment and warmed up GY tires. The caveat is "warmed up". GY tires need to be really warm before they start working well, driving down the freeway isn't going to get them there, at least not very quickly. I do my aggressive driving on a race track so my tires can get pretty warm.
The sidewalls are pretty short on these cars, so RF's or not, there isn't much difference in ride though the non-RF's will ride a little more softly. Personally, I like the quick handling of the RF's though right now I'm running Michelin PSS's, a non-RF tire.
As for noise, all tires are noisy. The non RF's may be a little quieter, but we talking marginally and something you'd need a dB meter to measure. There's an entire section on sound proofing your car but for some, that just adds weight and I don't want to do that. I actually don't find the noise all that bad and for me, it sounds like a sports car. Probably the biggest noise difference you will notice is changing from old rubber to new. New tires are always quieter but give them a year to "season" and it'll be noisy again, RF or not.
Old Jun 1, 2017 | 09:04 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default New Tires
NSF
Not too expensive and quiet.
Old Jun 1, 2017 | 12:57 PM
garydinapoli
Thanks for your time, now go back to sleep!!
Old Jun 3, 2017 | 06:23 PM
88redconvert's Avatar
88redconvert
I changed the original gy runflats on my 2012 at 9,000 miles to Michelin runflats and it made a considerable reduction in noise. Mostly from the rear tires. Just my 2 cents.
Old Jun 4, 2017 | 01:16 AM
polyol's Avatar
polyol
This is simple I assume you have 19x12 and 18x9.5's yeah?
Michelin Pilot Super Sports
Front: 285/35/18
Back: 345/30/19
Never look back. Get a Slime repair kit and pump and run with confidence.
Old Jun 5, 2017 | 01:05 PM
JoesC5's Avatar
JoesC5
Brand of tire makes a difference as the different brands will have a different construction, different tread design and different tread compound.
I dumped the OE Goodyear's and went with the Bridgestone RE050A run flat as that particular tire was designed specifically for the C6 Z06 as Bridgestone was trying to get the OE business from GM.
They are quieter, have better grip, way better in the rain, don't tramline near as bad as the Goodyear's and last way, way longer.
Mine are now 6 years old with ~38,000 miles on them and are ready for replacement. With that age and mileage, they have lost a lot of their grip and starting to get noisier.
But still quieter than the Goodyear's when they were new.
Old Jun 6, 2017 | 10:56 AM
nick14003's Avatar
nick14003
I got MPSS tires, non runflats, stupid expensive, but they grip so well. Tiny bit quieter and smoother ride, don't really notice the difference since it didn't bother me in the first place
To New tires???
