Need help with c6
Old Jun 2, 2017 | 12:13 AM
Chrish514222's Avatar
Chrish514222
Default Need help with c6
yesterday i was on dyno.. after a pull I went to slow down and downshifted with the paddle shifter. Well when I did that the 'service traction control' I believe came on.
When it did that, I can't downshift using the paddle shifters, cruise control don't work and when in D and you give it full throttle, it don't downshift.
I checked some fuses, took battery cable off fr 30 min and nothing.
anybody got any ideas?
Old Jun 2, 2017 | 01:20 AM
torquetube's Avatar
torquetube
By "and nothing" do you mean the problems went away or "and nothing" they didn't?
The dyno will confuse the traction control, especially if the front wheels are stationary.
Old Jun 2, 2017 | 01:25 AM
Chrish514222
sorry it hasn't went away yet, still doin same thing..
all the warnings went away, such as 'service traction control' but still same symptoms
Old Jun 2, 2017 | 08:09 AM
irok's Avatar
irok
traction control should be turned off while on dyno
Old Jun 2, 2017 | 08:22 AM
Chrish514222
it was turned off
Old Jun 10, 2017 | 11:59 PM
Chrish514222
it was turned off
damn no one? Lol
Old Jun 11, 2017 | 12:23 AM
Brandon619's Avatar
Brandon619
Have you checked for and OBD II codes? Also you might want to do a voltage test on your battery, these cars eat batteries and bad batteries cause issues in these cars
Old Jun 11, 2017 | 01:12 AM
Chrish514222
no codes, I think it's the bcm causing all of this.
Battery is 13.6-14 according to the car while running
Old Jun 11, 2017 | 10:55 AM
torquetube's Avatar
torquetube
What code reader are you using? Many generic readers won't even show the chassis codes that typically accompany the Service Traction Control message.
If traction light is on, there should be codes set.
Old Jun 11, 2017 | 12:10 PM
Chrish514222
used a tech 2 scanner.. it showed lost comms with sensor but I can't remember off the top of my head which sensor and there's no lights on at all.
something new I learned, the car sometimes takes off in 3rd gear(auto) then shifts fine after that. Just stil don't downshift under acceleration and cruise don't work
To Need help with c6
