ZO6 "H" pipe
Old Jun 15, 2017 | 02:52 PM
seevi's Avatar
seevi
Default ZO6 "H" pipe
Does anyone know how large the hole is in the connection tube on the "H" pipe on the ZO6 exhaust?
Old Jun 16, 2017 | 08:59 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Z06 H-Pipe (and X-Pipe on ZR1) are 3"
Thanks,Matt
Old Jun 17, 2017 | 09:11 AM
seevi's Avatar
seevi
Thanks,Matt
What is the diameter of the hole that connects the 3" pipes?
Old Jun 17, 2017 | 09:18 AM
madmatt9471
Sorry, I misunderstood.That I do not know. If I stI'll had one that had the H-pipe I would measure it for you.
Thanks,Matt
Old Jun 17, 2017 | 10:38 PM
mggray87's Avatar
mggray87
Thanks,Matt
would it be the same as the BBE X pipe... since it slips in the exhaust I don't have H pipe out yet but ill have it out in next 2 weeks but I have the X pipe sitting in my garage now I can measure it if im understanding it correctly.
Old Jun 18, 2017 | 10:01 AM
seevi's Avatar
seevi
Appreciate the effort!
Old Jun 18, 2017 | 12:36 PM
HOXXOH's Avatar
HOXXOH
I assume you mean the diameter of the pipe, since you can't measure the hole unless you cut the pipe apart.
Here's a pic that shows the cross pipe to be slightly smaller than the 3" pipes, so I'd suspect it to be 2.87 or more likely 2.75 OD.
Old Jun 18, 2017 | 05:30 PM
Javvy's Avatar
Javvy
I have seen a H pipe from a C5 and the hole is about 15mm across.
It's definitely not as big as the pipe, apparently doesn't need to be.
Old Jun 18, 2017 | 09:52 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It's very close to 3", though slightly smaller, as was already stated
To ZO6 "H" pipe
