06 convertible limit switch
Old Jun 18, 2017 | 12:39 PM
h8snow's Avatar
h8snow
Default 06 convertible limit switch
Need
Old Jun 18, 2017 | 01:25 PM
RicK T's Avatar
RicK T
Almost $300/hr for labor is ridiculous.
If you're asking about a DIY repair, member RLSebring did his 8 years ago, send him a PM and ask for tips or info.
Old Jun 18, 2017 | 03:03 PM
h8snow's Avatar
h8snow
[QUOTE=RicK T;1594971356]Almost $300/hr for labor is ridiculous
Old Jun 22, 2017 | 12:26 PM
veech's Avatar
veech
Post up any info u get... I keep getting the "top not secure" on my display
Old Jun 22, 2017 | 12:33 PM
RicK T's Avatar
RicK T
That is usually an issue with the microswitch in the windshield header, inside the driver's side hole that the top pin goes into. The lever on the switch gets a "little bent" or otherwise out of adjustment. You can correct that yourself with a little patience.
Examples:
https://www.corvetteforum.com/forums...e-message.html
https://www.corvetteforum.com/forums...e-warning.html
Old Apr 29, 2019 | 06:43 AM
mike_engr's Avatar
mike_engr
2010 C6 Convertible top not moving Open or Closed.... I possibly isolated the problem to convertible top switch. I know the switch is getting 12V, But when I bench-test and probe the 6 metal pins behind the switch I don't get any changes w/continuity across any of the pin pairs when I hold it UP or DOWN. Switch should switch the wire pairs that are connected, no?
Has anyone found a bad C6 Convertible (Power) top switch before? Anyone know the actual pin outs for the switch or a better way to test it??
To 06 convertible limit switch
