Brake rotor option
Rotors I would go with Centric (Stoptech) rotors (or OEM) and the Stoptech Z26 ceramic pads. If you aren't on a race track they will work well. If you want to go Carbotech the 1521 is probably a better idea than the AX6. The AX6 is going to give you dust and noise.
I got my Centric (owned by StopTech) slotted rotors from Tire Racks website with the Cabotech 1521 "Bobcats" and loved them. Stopping power is so much more precise and smoother than stock. I still have these sitting in my garage with only 1000 miles on them before I swapped them out if you're interested.
I swapped them out for track use recently for Centric blanks and Carbotech XP8s / XP10s.
On my z51 option, got 30K on the oem HD pads, and still had enough meat on the rotors to turn them for a second set of HD pads to get me to the 60K mark.
As for the Carbotech 1521 pad, about the same feed back and initial bite as the OEM HD pads, but do not have the higher working heat range as the HD pad instead.
As for drilled or slotted and even pads, really need to think of the heat range the rotors and pads are going to be run. The drilled rotors do well with off gassing from the pads and cooling flow through the rotors surfaces, but have the stress cracking if you doing a lot of High speed track kind of use. As for pads, they do have a heat range to them, so too high of a heat range before they come on line, and may have ***** for stopping power during DD driving. To low of a working heat range on the pad, and you just burn them up quickly instead.
To bottom line it, short of the dusting and shorter life of the HD pads, the do very well for the heat ranges they where designed to run. Hence good for stock cold to about 1000*.
The 5000 are now expensive but the 4000's work great and last well.
Running 1521 pads with these and it's a great combo that works well.
Wouldn't do the drilled. They look great but crack to easily.
Front CT731 1521 $140.60
Rear CT732 1521 $121.60
Since the install few years ago, I experienced no negatives. However, I did sealed wheels with RejeX as well as painting rotors prior to install. I seldom use or pampered my C6, only time my OEM polish Gumby clear coated wheel barrel gets cleaned is when I got caught in an occasional messy Trade shower and if showers are light, I let it go without cleaning.
So...between an occasional Street driven pleasure and minimum care, my combos are great!
Might be an entirely different scenario if not taking protective shielding precautions along with total neglect overtime.
