Hi I have a 13k miles ls3 out of a camaro, anyways it's going in a 93 rx7 with a t56 trans an z06 clutch. The car weighs 2700lbs with engine and I was looking at the gm asa cam out of the 525hp ls3 crate engine. What's your thoughts? And do I need to get springs and retainers?
Richard
Richard
have seen that cam make 480rwhp in a M6 Camaro.I run the hot cam version of it with 112 lsa instead of 110 lsa.mine made 650rwhp with it and gentle on the valve train.at 2700lbs it would fly
What kind of power adder do you have to make 650 at tires with hot cam
Any of the GM cams are complete junk. Call BTR and have him help you select a cam, or have Pat G spec a custom grind out.
Almost any aftermarket cam will need springs, retainers, seals, pushrods, etc.
There are so many far better options out there. I would just give BTR a call and go with one of his full kits.
Is it going to be a carbed setup? Hell, with a manual and that kind of weight, I would personally consider one of the new low-lash solid lifter grinds. But with that, you would have to lift the heads to change the lifters, which it would be beneficial to do anyhow, imho. With a solid roller you could really spin that thing to make serious power in the upper rpms and probably make more torque to boot.
Thanks for the info, I will just have a cam speced, I am running fuel injection and also do not want to remove heads to do lifters, engine only has 13k on it it's from a 2015 camaro
Yeah I would love to do a blower but I do not have a ton of room for a blower, I would need a lower profile lsa lid to make it work or something that is not much taller than stock ls intake.
