I have a 2006 LS2 Corvette. my right side fog light does not work. replacing the bulb did not work. I think it is the wire harness from the fuse box to the bulb harness connector. used 12 v volt meter and did not get a reading with power applied. I believe that it might be the harness. Can you provide any other trouble shooting procedures that might lead to the problem
For best answers on C6 problems/questions, post in the C6 Forums instead of the C5 Forum where this thread started its life.
Disconnect the battery at the battery terminal, remove the battery to block cable, loosen the 4 7mm bolts until the free spin, and you can pull the upper block off the lower block.
To separate the upper fuse block, you need to remove the grommets that hold the upper block together.
And the below link that SenseofTouch did a write up, that will walk you through it if the problem is in either the lower block, or in the upper fuse block trace wires.
