Harmonic Balancer Bolt
Old Jul 6, 2017 | 09:46 AM
mi253's Avatar
mi253
Default Harmonic Balancer Bolt
Hi Just for the third time replaced harmonic balancer bolt. 2005 C6 Car has 111000 miles on it. Mechanic has been same each job, I asked for him to use red locktite, and at the advise of Master GM mechanic used blue instead, think I'll be Ok?
Old Jul 6, 2017 | 10:03 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Was it a new bolt that was torqued correctly?
Old Jul 6, 2017 | 10:04 AM
jaredtxrx's Avatar
jaredtxrx
Why is this the 3rd bolt?
Is is backing out?
Are you having to replace the balancer again?
Old Jul 6, 2017 | 10:16 PM
CI GS's Avatar
CI GS
One would need a bit more detail than that to give you any sort of reasoned opinion.
At the very least:
- what was the frequency of bolt replacement in term of time/miles between each bolt change? Did these three bolt changes happen over the span of many miles/years, or was it all in one weekend?
- Did the same mechanic do the same thing - i.e. Use blue Locktite - on each occasion? You are aware that the very definition of madness (and, perhaps, stupidity) is doing the same thing over and over and expecting a different result, right?
- was it a GM bolt? If so, was it new? If so, it comes coated with a sealant under the head from GM, and it's a torque to yield bolt, so I'm not sure if you're supposed to use any Locktite. I would still use it though;
- was it torqued properly?
- I have always only used the red locktite on any harmonic balancer (it's actually a dampener, not a balancer) because the job of that part is to absorb millions of harmonic vibrations from the crankshaft during the life span. If anything needs red locktite, it's that bolt.
To Harmonic Balancer Bolt
