C6 Dash Removal
Old Jul 7, 2017 | 07:45 PM
VaughnCo's Avatar
VaughnCo
VaughnCo
Default C6 Dash Removal
Does anyone have any links they can share with me on DIY Dash Removal. I'm going to attempt to fix the AC Actuators. After reading dozens of threads here on the subject, think I got this!!!
Old Jul 7, 2017 | 08:08 PM
RicK T's Avatar
RicK T
This is changing a dash in a Z06 but I think it gives you all you need.
http://www.kawal.net/Dash%20Replacement.htm
Old Jul 7, 2017 | 08:33 PM
Dcasole's Avatar
Dcasole
do you have to remove the dash in a C6 to get to the actuators ??
I did them on my C5 and was able to replace them all without a dash removal
Dave
Old Jul 10, 2017 | 12:03 AM
Corsair79's Avatar
Corsair79
Here you go, the guides on this site are great. Used this when I partially removed the dash to fix my remove and repair my HUD. It's takes a little time but is not that bad. Keep track of all the screws, bolts, and fasteners and where they all go.
http://www.theredlion.us/C6%20Dash%20Replacement.pdf
Old Jul 13, 2017 | 06:36 PM
VaughnCo's Avatar
VaughnCo
VaughnCo
Is there a way to work on the Actuators with out removing the dash?
Old Jul 13, 2017 | 07:22 PM
Dcasole's Avatar
Dcasole
I would sure as heck try , i did replace my C5 actuators without removing the dash , it was a little tough but it was better than the alternative
Not sure if u can do the C6
Dave
Old Jul 13, 2017 | 08:00 PM
RicK T's Avatar
RicK T
There is an actuator you can access without removing the dash but if your problem is one or more of the mode door curtains then the dash does have to come out.
Check this:
https://www.corvetteforum.com/forums...placement.html
To C6 Dash Removal
