LS2 will run on 1 O2 sensor
Old Jul 11, 2017 | 02:40 PM
Orion2011's Avatar
Orion2011
Default LS2 will run on 1 O2 sensor
Sunday I learned the hard way that the car will run fine with only 1 O2 sensor.
I have a wide band with narrow band simulation in the left bank. Sunday my AFR gauge was acting up. Eventually the CEL came on but the car ran fine.
Turns out my buddy who was with me must have stretched out(big guy) put pressure on my WB O2 controller under the floor board where the Audio amp is. Plugged everything back in and the WB started working again.
I always wondered if I would be SOL if the WB ever failed on me. Now I know.
Old Jul 11, 2017 | 03:21 PM
schizcat's Avatar
schizcat
Car will run fine. Remember, the O2 sensor just senses how much exhaust is coming out of the engine. In theory, one the exhaust stage of an engine cycle is complete, there is no more issues with the functionality (if that makes sense). Unless you are running turbos or have a clogged cat, performance shouldnt be an issue.
Old Jul 11, 2017 | 03:22 PM
BlindSpot's Avatar
BlindSpot
Turns out my buddy who was with me must have stretched out(big guy) put pressure onmy WB O2 controller under the floor board where the Audio amp is. Plugged everything back in and the WB started working again.
yes a CEL will set but the ECM is pretty adaptable. It will just revert to fixed fueling.
Old Jul 11, 2017 | 03:25 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I've always told people to not set it up like this.. yes, it will run, but it's really not ideal IMO
Mine ran like **** and would barely stay running when it happened on mine, so I got rid of that setup and just added another bung
Old Jul 11, 2017 | 03:35 PM
schizcat's Avatar
schizcat
So are you running your 2 rear sensors and the wideband?
Old Jul 11, 2017 | 09:12 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
No need for rear sensors. Running both fronts + added an additional bung for wideband pre-cats
Old Nov 24, 2021 | 08:12 PM
the_slo_vette's Avatar
the_slo_vette
You added an extra bong to the headers?
Old Nov 28, 2021 | 07:32 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes
To LS2 will run on 1 O2 sensor
