Clutch micro switch on 08+
Ok I've done some searching and not found an answer yet. I searched back to threads from the past 5 years and all anyone says is that the 08+'s have the position sensor but no solutions besides the LPE box.
Who has hooked up a two-step on their 08+ car without using the LPE box to convert the position sensor signal?
Where/how did you mount a micro switch?
I'm not seeing any good/easy way to mount it up so I'm fishing for ideas before I re-invent the wheel here.
Thanks!
Thanks!
Thanks!
Thanks!
I have a couple friends that installed the 2 step using the pedal to create a ground when pressed with a little mod. Careful for what you wish for though. Between those 2 they've broken 3 axles, 2 diffs, a torque tube, and a half shaft
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Former Vendor
Clutch sensor vs switch
Obviously mounting a switch to the newer cars is a viable solution but using our box does have a few advantages (in addition to the simplicity of not having to mount another sensor and bracket). With our module you can enable/disable the output in 1% increments without having to re-position the bracket/switch etc. Also you can change the hysteresis so you can have it open/close in a narrower or wider range (so it takes more or less travel before it turns back off or on as you release the pedal).
BTW - that same module can also be used as a TPS or MAP based switch or any other 0-5 volt output type sensor switch (but it can't be used on the newer direct injection Gen V V8 vehicles that have a serial data based throttle position signal, for that you need our CAN based relay module).
Thanks!
Thanks!
