Radio/ A/C controls change to irridescent
Cruising
My radio and A/C control panel looks normal when I start the car and after a minute or so the two displays turn kind of irridescent. I can still read the settings. Also the passenger vents blow cool air, while the driver side vents blow warm air.
Is there something wrong with the radio and a/c controls? I've read some other posts on the air temps blowing from the side vents so that must be a low r134 or other problem.
I think you may have two different problems.
1) No the r134 is more than likely NOT the problem.
2) AC could be the head unit...$400
3) AC could be the air ducting dividing doors in the dash...dash removal to fix.
4) Radio and AC display both dimming...unsure perhaps sun sensor in center top of dash?
I think you may need to go to a shop to diagnose as opposed to this internet forum.
Only suggestion is to disconnect the battery for 10 minutes (don't forget to re-index your windows) and hope for luck.
And good luck.
And good luck.
blkbean (07-20-2017)
Cruising
In addition to the display problem, the radio doesn't work, no sound, no tuning. The CD player does work and sounds fine. Are these displays LCD? I know they are not LED like the c5 models. Guess I'll take the radio and A/C controls out and see what I can find.
Cruising
What is the problem with the other key fob? I haven't seen any warning that the battery is low.
