C5 T56 in a C6
Old Aug 20, 2017 | 11:31 AM
ogulcanio's Avatar
ogulcanio
Default C5 T56 in a C6
Hello everyone,
Can a T56 from a 2003 C5 used as direct replacement for a 05 Z51? I Are bolt pattern and lenghts are the same? Also the gear ratios
Any comments will be really great
Old Aug 20, 2017 | 12:58 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
All base C6 manuals use the 27 spline output shaft.
Use your C6 shift rod.
Wire the extra plug on the 05 to the existing plug on C5 trans.
2005 is a one year dual plug on trans
Old Aug 23, 2017 | 04:01 PM
ogulcanio's Avatar
ogulcanio
I guess I need to use the C6 housing right?
And C5s and base 05 C6 manuals are using the same output shaft right?
Old Aug 25, 2017 | 09:39 AM
Brandon619's Avatar
Brandon619
No 2005 C6 is the only year C6 that can connect to the C5 diff. No tail housing needed.
To C5 T56 in a C6
