Adding XM 'module'
Old Aug 21, 2017 | 11:40 PM
JsC6's Avatar
JsC6
Default Adding XM 'module'
I added Nav radio to my 05. (Am meeting with a friend tomorrow 8/22 to get rid of 'Theftlock') I also was given the XM module. I know the module goes above the left wheel inside the driver side carpet in rear. Is there a wire there that I'm suppose to unplug and/or plug into the XM module?
Old Aug 22, 2017 | 08:45 AM
jaredtxrx's Avatar
jaredtxrx
You should have these 2 wire harnesses. The big blue one that is disconnected is the XM antenna plug. If not, you will need to source them somehow.
Old Aug 22, 2017 | 06:04 PM
JsC6's Avatar
JsC6
Default My previous radio was a 6 disc changer, has radio...
My previous radio was a 6 disc changer, as far as I know it didn't have XM. The nav radio I bought, came with an XM module. Are the wires you speak of in that compartment plugged in to something? I don't see an XM button on radio screen. Will it pop up when I plug it in?
Old Aug 23, 2017 | 09:17 AM
jaredtxrx's Avatar
jaredtxrx
My previous radio was a 6 disc changer, as far as I know it didn't have XM. I don't see an XM button on radio screen. Will it pop up when I plug it in?
The "XM" button will show up on the screen when you hit the "Source" button on the outer part of the head unit.
I'm not sure which compartment you are talking about?
Old Aug 23, 2017 | 09:13 PM
JsC6's Avatar
JsC6
Excellent, the XM button magically appeared after I installed the XM module. Shout out to Ray Kawal - He said on his website that it would be hidden... and yes it was. As well as covered in black electrical tape - Just as he said. Here is his link, http://www.kawal.net/vettemods.htm
Old Aug 31, 2017 | 12:36 PM
JsC6's Avatar
JsC6
In addition... I found the plug for the XM module, but, where are the green and yellow connections to plug into the XM module? There is no XM antenna on top of the halo. Does that mean I won't find the yellow and green plugs?
BETTER QUESTION... Is the long black box mounted to the right of the rear view mirror on the windshield an XM antenna or is that for OnStar?
Old Aug 31, 2017 | 03:56 PM
Patsgarage's Avatar
Patsgarage
The windshield box is the OnStar antenna, I think the XM antennas are located in the rearview mirrors on the later cars, but if your 05 does not have the wart on the halo then there is no XM antenna in your car. I thought all C6's had XM as standard, but I could be wrong on that one.
To Adding XM 'module'
