camshaft advise
Old Aug 26, 2017 | 01:55 PM
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
Default camshaft advise
Here's my question. I'm in the process of purchasing a used Z06, narrowed it down to a few, some w/modded cam/headers. I know the stock LS7 cam has around.591 lift. What is the most lift to keep the drivability under control, great performance w/great sound yet avoid the bucking, unfriendly issues for street/crusing/travel. I travel a lot and am planning on serious road trips once purchased. Any of you w/experience on this will be appreciated. Thanks...
Old Aug 26, 2017 | 02:07 PM
KW Baraka's Avatar
KW Baraka
Lift has little to do with ANY of the issues you site.
Since you apparently know so little about cams, I STRONGLY suggest that you get with a reputable vendor (like Cam Motion), speak with them about your goals, and have them suggest which of their cams will work best for you.
Not tryin' to bust your chops......but speaking to lift as opposed to valve events is really missing the boat.
KW
Old Aug 26, 2017 | 03:21 PM
iw172's Avatar
iw172
still looking for spec numbers that worked for you guys with similar drivability results
Old Aug 26, 2017 | 06:35 PM
Unreal's Avatar
Unreal
Driveability is complete subjective. One person will say a 25 degree overlap drives great, other will hate a 5 degree overlap.
Overlap has the most to do with driveability. Stick under 5-8 degrees and most people won't complain, but some will.
I would do the Pat G form, and do what he says.
Old Aug 26, 2017 | 06:37 PM
iw172's Avatar
iw172
thank you. that's the kinda stuff I'm looking for
Old Aug 26, 2017 | 08:20 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I just had Pat G custom Spec a Cam for me and I will be having Texas Speed grind the specs -
The specs are "Specific" to my Vette, bolt ons, driving, tranny, gears, use of the Vette, emissions, etc. (there is a entire sheet to fill in)
Lift, Duration and Overlap (- or +) all will play a huge factor -
https://www.guerragroup.com/camshaft-help
The very little you pay and the amount of time you take to fill in and answer the questions on the answer sheet (and as much detail as possible too) is worth every penny $25 for non rush or $40 for rush to order specs
Thanks,Matt
To camshaft advise
