C6 won't turn over. PLEASE HELP!!!
Old Aug 30, 2017 | 11:40 PM
Ziggy.C's Avatar
Ziggy.C
Default C6 won't turn over. PLEASE HELP!!!
I have a 2007 corvette. It is not cranking. The battery is only 6 months old. I still had it tested to to make sure that wasn't the issue. Battery tested good. I then thought it was the started, it was good but replaced it anyways. I check all fuses and relays. All fuses are good, relays were good to but replaced the powertrain control relay, starter relay, crank relay, fuel relay. It was running fine no issues what so every. Parked it in the garage and about a week later I went to clean her up. Wiped her down, then went to clean engine bay. Removed hood for a deep detail clean. Then proceeded to remove intake(fast102), removed valve covers and polished them up. Put everything back together and now won't start.
Old Aug 30, 2017 | 11:42 PM
JerriVette's Avatar
JerriVette
Put key fob in the glove box slot and see if it's the key fob not communicating?
Just a guess...
Good luck
Old Sep 1, 2017 | 06:36 PM
Ziggy.C's Avatar
Ziggy.C
Thank you sir, I have tried this. Was not successful
Old Sep 1, 2017 | 07:30 PM
tennblkc6's Avatar
tennblkc6
duplicate thread...
To C6 won't turn over. PLEASE HELP!!!
