Remove driver side inside door panel
After having some work done at my dealer I noticed the driver side speaker grill was pushed in. Mechanic probably hit it with his knee. How can I take off the panel to push out the grill?
I would personally just fit a small 90 deg pick into the holes and pull it out but here is a PDF with instructions on removal as requested.
http://www.theredlion.us/DSV%20Drive...%20Install.pdf
This thread can help you with reinstall. https://www.corvetteforum.com/forums...ll-method.html
Good luck!
Good luck!
