2005 rear diff problem question
Old Sep 15, 2017 | 11:20 AM
ruinms's Avatar
ruinms
Default 2005 rear diff problem question
I have an 2005 and am very nervous of beating on the car because of the rear diff issues. I bought my car with 90k all stock except for a corsa exhaust. you would think that the diff would have already been broke/ replaced.
My question is, is there a date or a number on it that I can look at and see if its the original diff?
I did an h,c,I setup on it and looking to take it to the track.
Old Sep 15, 2017 | 03:10 PM
Dano523's Avatar
Dano523
The problem with the 2005 diff is the case is not as strong as later diff cases. So when the diff case cracks apart, it pretty much obvious.
http://www.rpmtransmissions.com/page6.html
Old Sep 15, 2017 | 03:27 PM
Unreal's Avatar
Unreal
Get under the back of the car and look at the diff. You can see if it is still a 05.
Old Sep 15, 2017 | 03:39 PM
ruinms's Avatar
ruinms
But how can I see if its still an 05 by looking at it?
What am I looking for?
Old Sep 15, 2017 | 03:55 PM
Unreal's Avatar
Unreal
The bolt pattern or tail housing of the tranny. Totally different, along with the diff itself. The ribs/external structure is way different.
Old Sep 15, 2017 | 04:10 PM
RicK T's Avatar
RicK T
'06 on left, '05 on right
Ooops, forgot to credit Walt White Coupe for the pics.
Old Sep 16, 2017 | 03:41 PM
Zachary Gregg's Avatar
Zachary Gregg
This is what an 05 will look like
Old Sep 16, 2017 | 09:42 PM
OneMoreVet's Avatar
OneMoreVet
St. Jude Donor '25-'26
Every time I see one of these pictures my roll mph goes up! Just once I wanna put on a set of DR's and let er hang out without fear of causing thousand in damage.
One way or another I'm looking at $$$$'s
Old Sep 18, 2017 | 02:30 PM
rhoyvald's Avatar
rhoyvald
Isn't another way to check if it's an 05 is that the damn drain plug on the diff is right above the leaf spring?
Old Sep 21, 2017 | 08:25 AM
ruinms's Avatar
ruinms
That's a good Question?
To 2005 rear diff problem question
