Ongoing Electrical problems
Old Sep 21, 2017 | 08:06 PM
1993C4LT1's Avatar
1993C4LT1
Default Ongoing Electrical problems
So my friend's 06 would start occasionally, and throw a service charging system message. Got under the car, and saw the starter solenoid post broken. We changed it yesterday, and battery voltage was great.
Today, it wouldn't start, and no lights. He moved the positive battery cable, and it started. Now, it won't start. I saw this under the car yesterday. Could this be the cause?
And yes, we did wrap the starter and solenoid in heat shield to be safe.
Old Sep 21, 2017 | 08:36 PM
RPOWU8's Avatar
RPOWU8
Yes, Those cables need to be replaced. A poor connection is the likely cause of the solenoid melting. A bad connection generates a lot of heat which is enough to melt the bakolite the solenoid is made of. I would replace the positive cable from the battery to starter with a new stock cable. Replace the wire that goes to the alternator with a -0 gauge or 2 gauge wire and route directly to the post on the fuse block.
Looks like the copper cable is oxidized really bad causing your current issues.
DJ
Old Sep 21, 2017 | 08:42 PM
Sayfoo's Avatar
Sayfoo
Sounds like it is mostly the battery or the cable end at the battery. The cable at the starter is not the worst I've ever seen, but it could use some TLC
Old Sep 21, 2017 | 08:43 PM
RPOWU8's Avatar
RPOWU8
I got my alternator cable from Brett. Post #98
https://www.corvetteforum.com/forums...post1592874221
Old Sep 21, 2017 | 09:13 PM
1993C4LT1's Avatar
1993C4LT1
You guys rock
Now, I've never replaced cables like that in my life. Any tips on how to do so?
And I charged the battery yesterday. It's reading at 12.65 volts at the moment.
Old Sep 27, 2017 | 01:47 PM
1993C4LT1's Avatar
1993C4LT1
At the dealer and they want to sell a bundle of wires for the alternator wire. Does anyone know where to get the wire from? Or do I have to buy it all?
Old Sep 30, 2017 | 05:28 PM
1993C4LT1's Avatar
1993C4LT1
Sent him a PM. Learned a lot today. No one sells the alternator ground wire by itself.
Old Sep 30, 2017 | 06:26 PM
Dcasole's Avatar
Dcasole
can't you just buy a new end , remove old , clean up the wire and install the new one .... I would even probably venture to actually solder it after crimping as I am not a crimping fan ...
Dave
Old Sep 30, 2017 | 06:36 PM
1993C4LT1's Avatar
1993C4LT1
Thought about it. Hard to tell the first pic I posted, but some copper strand are broken off. And if I cut to where it looks where all wires are intact, it won't reach the starter. Even now at the stock length, it takes effort to get the alternator wire on the starter post. But I don't know, wiring isn't my strongest knowledge.
Old Sep 30, 2017 | 06:54 PM
Dcasole's Avatar
Dcasole
make an extension , solder new end on bench, then solder other end to the harness, wrap in high heat tape and u will be good as new
Dave
Old Oct 1, 2017 | 08:55 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Just a guess: is/are those wires "chewed" on? They kind of look it it to me. If so, something needs to be done to prevent it as well as replace/repair.
Old Oct 1, 2017 | 12:52 PM
1993C4LT1's Avatar
1993C4LT1
Yes and yes. Will work on it a bit.
Old Oct 1, 2017 | 05:15 PM
cclive's Avatar
cclive
Anyplace that sells copper welding cable.
To Ongoing Electrical problems
