1 Red primary at idle
Old Sep 26, 2017 | 08:33 PM
Nopps's Avatar
Nopps
Default 1 Red primary at idle
Started the car for the first time in a few weeks, last night. When I walk over to the engine bay, I notice 1 header tube is red hot at idle....I've seen a similar issue on other ls cars before after a battery is disconnected, or voltage is low ect, but never isolated to one hole. Usually a whole bank or both banks....but this time it's only at one cylinder? And everytime I've seen it happen in the past, it either works itself out after a bit or an ignition cycle would take care of it. This doesn't seem to be going away. Fuel needs to be getting past the valve and burning in the pipe for some reason...and it must be burning good because I don't see a change in afr on the wideband. Has anyone seen this before?
Old Sep 27, 2017 | 09:29 AM
spartan8270's Avatar
spartan8270
Try swapping injectors from one cylinder to that cylinder and see if problem persists. Even though AFR looks right could be a possble stuck injector
Old Sep 27, 2017 | 10:11 AM
81turbota's Avatar
81turbota
+1 on injector. Which bank is your WB02 sensor hooked up to?
Old Sep 27, 2017 | 10:17 AM
Nopps's Avatar
Nopps
I've got a dual wideband...I guess it's worth a shot. Was tossing that around yesterday but couldn't get past the lack of a reaction on the w/b. I'll give it a shot.
To 1 Red primary at idle
