Acceleration Flat Spot -2013 Coupe
Old Sep 27, 2017 | 06:22 PM
rgamache's Avatar
rgamache
Default Acceleration Flat Spot -2013 Coupe
When the engine is cold and accelerating in 1st and 2nd, there is a hesitation ~2000-2500 rpm. RPM briefly drops so not a clutch slip. Once the engine has been driven a few miles the issue goes away. Was there a few months ago, went away and came back this week. I have searched this forum and Googled. Idle is smooth, engine does not run rough. The air filter seems clean and I also cleaned the MAF sensor with MAF sensor cleaner. 26.5K on the clock. I do have a fuel pressure gauge if there is a convenient connect point after the fuel filter. I am not thinking injectors or coils/plugs as it does not run rough. Any suggestions?
Old Sep 28, 2017 | 02:52 PM
Joni Lynn's Avatar
Joni Lynn
Wow, not one response yet. Not even one of the trolls telling you to go back to the search feature. This section of the forum has sure slowed down. A few years ago I think you would have had useful replies instead of this one. Best wishes.
Old Sep 28, 2017 | 04:34 PM
extrapilot's Avatar
extrapilot
My car does that slightly when cold, but in a few miles, it runs like a champ. A/F ratio is not at it's best, IMO, that's probably whats happening.
Old Sep 29, 2017 | 06:05 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd think extra is correct but the only other thing I can think of is a possible fuel pump getting weak (that wouldn't explain not doing it when warmed up). I thought the fuel rail had a connection point for a gauge---someone will chime in on that one.
To Acceleration Flat Spot -2013 Coupe
