auto shifter neutral & drive only
and tried to shift out of park. Would not move. I finally got it into move
to neutral and drive. I moved into my parking spot and shut it off. Put it
neutral and put the emergency brake on. I didn't realize that it was draining the battery in that position. When I shut the door the car beeped 3 times and locked. Never did that before. Does that sound like the shift cable
or other problems also. The car has 10,000 miles on it. Is this an easy fix? Thanks
