Too soft shifts
BTW, this great-grandpa has a bone stock Caddy and a modded Vette with hundreds of 1/4 mile passes on it. The "feel" of the shifts is nearly identical.
Its part of Edlebrocks box tune that you flash in when the super charger is installed.
Hence not only does the reflash hobble the motor some more via TM, but it also softens the shifts as well.
The reason for this, with the Super charger in play, the torque curve just went linear from idle up instead.
So before the roots super charger, the torque would climb with the HP, and now with the roots blower, Torque is from about idle up, and you gain only HP with the revs isntead.
Bottom line, someone goes into the tune and de-hobbles the TM to allow all the power to go to the ground instantly, and firms the shifts back up too firm, your not only going to be roasting the tires every time you try to take off, but the car getting sideways ever shift as well.
As for with the super charger, it still has a lot more power to give you by spooling it up, but to pull this off, you need to install a meth kit isntead. The meth mix will not only help to keep the motor cool between boost hits, but keep the octane levels high enough so you don't get detonation with the higher boost levels as well.
