size rotor
The rotor sizes are as follows dependant upon the Option code of the vehicle (ie: Z51-Base-Z06)
You either have the Base or Z51 rotors.
Look at the Option code in the glove compartment and see if you have the Z51 RPO code.
Here are the rotor sizes.
C6 Rotor Diameters in inches
Base.....front 12.8 x 1.26 rear 12.0 x 1.0
Z51......front 13.4 x 1.26 rear 13.0 x 1.0
Z06......front 14.0 x 1.26 rear 13.4 x 1.0
ZR1.....front 15.5 x 1.42 rear 15.0 x 1.34
89060328 - Z51 Front Rotors (OEM)
88909667 - Front Ceramic Pads (OEM)
89060329 - Z51 Rear Rotors (OEM)
889096668 - Rear Ceramic Pads (OEM)
I'm terribly sorry for even mentioning Z51 in my reply for rotor sizes.So basically, your saying that a Z51 Optioned car would have the J55 HD brakes. I do believe I did mention the Z51 RPO code which as you know, does include the F55 RPO HD brake code.
I would think that most members on this forum know exactly what I meant in my post. Most may not know that J55 are the same brakes as on a Z51 optioned car.
Have a great day
I'm terribly sorry for even mentioning Z51 in my reply for rotor sizes.So basically, your saying that a Z51 Optioned car would have the J55 HD brakes. I do believe I did mention the Z51 RPO code which as you know, does include the F55(I assume you meant J55 ?) RPO HD brake code.
Have a great day
Most simply stated is that JL9, J55, J56, & J57 are brake codes, not base, Z51, Z06, or ZR1. Without defining the brake codes, owners of Grand Sports or other cars with certain options, have no assurance what brakes the car had when it left the factory.
