headlight nuts?
Old Oct 31, 2017 | 01:36 PM
tomslik190's Avatar
tomslik190
1st Gear
Default headlight nuts?
MY 13 GS was in the body shop about a year ago to replace the drivers side fender that was damaged in a parking lot incident (somebody hit me while the car was parked). While washing it a couple weeks ago I noticed the headlight assembly was very loose. I discovered that the 3 nuts holding the headlight assembly to the substructure were MISSING!
I ordered 3 new nuts from the local dealer and just picked them up. The captured washer appears to be TOO SMALL and if I try to use them they will likely go right through each of the 3 large holes in the substructure, so they wont secure the headlight. I looked at the blow up of the parts schematic before I left the dealer and they did order the correct part #. The part they gave me is 1158-8331. These nuts happen to be the same size as the other nuts I removed that hold the bumper cover to the fender, right in front of the front wheel. is this the correct part number? I know the headlight nuts and the fender nuts have a different diameter captured washer, the headlight one being larger. How do I get the right part? I would think getting parts for a 4 year old car wouldn't be this difficult! damn you GM!
Old Oct 31, 2017 | 01:58 PM
RicK T's Avatar
RicK T
Suggest you contact RLSebring. He's the C6 headlight guru here and can likely hook you up with whatever you need.
https://www.corvetteforum.com/forums...-310-00-a.html
Old Oct 31, 2017 | 03:10 PM
R_W's Avatar
R_W
Or simply add a larger washer between the nut and the bracket. Wouldn't hurt anything and still gets the job done.
Old Oct 31, 2017 | 07:57 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I lost one of those a few months ago during a project and just replaced it with an m6 nut and a large washer.
Old Nov 3, 2017 | 09:19 PM
05 Wreck's Avatar
05 Wreck
1 1/4" fender washer at Lowe's, Home Depot, etc.
To headlight nuts?
