2008 ls3 M6 SpinMonster cam setup results
Alright guys,
So as it has been done before but not really alot of dyno sheets or videos showing it, I want to post my results from the build that I finally pulled the trigger on. I am the original owner of this vette, bought back in 2009. I am currently at 111,000 miles with the factory motor and honestly no issues at all with anything (knock on wood)
Parts 1st dyno:
Hinson 1 7/8 ceramic headers
off road x-pipe (no cats)
ac delco spark plugs and wires
Vortex v2 ram Air CAI
throttle body spacer
Tune from a Local shop
Max Power=411.58
Max Torque=414.48
I wanted alot more Rwhp so I decided to do a ton of research. I wanted a Cam that was not to going to be a headache as I do use my vette as a daily driver. After hours of research I decided to give spins cam a try and he was more then helpful to send me to the correct place to purchase his cam. Now I also didnt want to have to pay for more then one dyno tune so I opted in two having my intake manifold and ported throttle body ported and having everything done so that I would just have to run one dyno.
2nd dyno Parts:
SpinMonster 230/234 .613/.598 114 Custom Cam
* PRC .660" Dual Spring Kit with Titanium Retainers
* GM Front Main Seal
* Texas Speed 5/16" Hi-Tech 7.425" Chromemoly Pushrods
* ARP Harmonic Balancer Bolt'
Radically ported Intake manifold and throttle body
Tune by a different shop.
I kept my stock timing chain ( I know its a risk yada yada yada) as the owner of the shop said it shouldnt be a problem at all as he has had 2000 rwhp vettes that still have the stock timing chain and no issues. I kept the original oil pump as it showed no signs of failing and is running strong. My results are
Max power=488.87
Max torque= 451.39
Now, (hopefully I didnt miss/forget anything) How does the car drive?
absolutely amazing!!! spins cam is exactly as he said it was, very driveable identical with stock until you WOT. Didnt get rid of my slight surge ive always experienced but its not even bad and im not complaining as that could get better with a little more fine tuning. Overall a well investment as I will be doing heads asap!! just want a little more power to wheels. If you are wanting a car that you could drive across country(as I do all the time because of my family) then I highly recommend this setup, super smooth car has plenty of room to grow for hp, and it makes close to 500rwhp. Now if i did a pulley I would be kissing if not over 500rwhp but didnt want to spend another $400 at the moment. Overall I am 100% pleased and will be glad to answer any questions anybody has.
Parts 1st dyno:
Max Power=411.58
Max Torque=414.48
2nd dyno Parts:
Max power=488.87
Max torque= 451.39
Received 4,713 Likes
That's a nice gain from a cam & intake!!
joshblevins (11-04-2017)
Very nice results -
Who did the porting on the Intake manifold and does it have the Radius Rod mod as well?
Thanks,Matt
Thanks,Matt
Bob from peakspeedshop did the porting on the intake manifold and throttle body at very reasonable price. I also got my entire cam setup for him too. And also no radius rod mod was done just radical porting.
I am going to do the Gwatney/Rick Crawford and even another gentleman does them as well, with the Porting and Radius Rods in the LS3 intake pretty soon.
I might even do one of the GZ Vacuum pumps just for the heck of it - I can't really do LT's here in California, even though you can get away with it at times knowing the correct people.
I just finished a mild PatG cam in my A6 LS3 and was thinking that the last two bolt ons would be the Manifold and GZ Vacuum Pump - with the exception of an UD crank pulley, but I decided against it and went with the ATI stock size lighter weight balancer.
Thanks,Matt
Right on and thank you -
Thanks,Matt
Thanks,Matt
yeah i heard cali is strict with all the laws, i know if i wouldve went with a pulley i wouldve hit the 500 mark. I just didnt wanna spend the extra 450 for it lol. Im in nc as long as you know somebody here you can get away with alot of things. Good luck on your build man!
Thanks,Matt
Dang that's a good result.
Congrats.
Congrats.
Great results I should be getting mines back hopefully next week. I'm doing everything at once i have only a Poor mans CAI and Ported Throttle body at the Moment.
One thing ive seen just from reading, is that as long as the cai is pulling from the outside of the car then youre good, ive seen people take the stock cai and cut out a little bit of the shroud and put a box around it to keep the engine heat out of it and they ran pretty dang good. The route youre taking is cheaper, i was goong to wait to so the same but i just got impatient and payed for two dynos 😂😂😂 did all the work myself on the first mods, just didnt have the time to slam the cam in myself. Definitely post your numbers up when you get it back!!!
111.000 miles and you left the stock chain in? a $100 was going to be a deal breaker? I guess you saved $ on seals and gaskets too.
There are hundreds if not thousands of modded C6s without issue. Now that is not to say you don't have to worry. Yes, worst case scenario your entire motor will be gone. If you are planning on a cam/UD it would be wise to upgrade the TC as well. The problem is that no one has yet to figure out a "definitive" cause of the TC breaking. Some say it's too much power. Others say it's the balancer/pulley. And some say it's either a defective part or faulty instal and valve train harmonics. This is what is so frustrating because we can't pinpoint the cause and remedy the situation. Now when they pulled apart i had them check the tc to make sure it was all right, i already had the c5r chain bought. The cam chain tensioner was shattered and laying in the oil pan as it is only plastic, that could be one of the major issues with a failed tc. And in what i know makes perfect sense, the shop wanted another 350 to drop the oil pan remove the oil pump and changed the tc. The mechanic at the shop has 2000hp vettes that still run stock tc, is it a risk ABSOLUTELY, do i know the outcome if it goes south? ABSOLUTELY. Build wasnt cheap and i didnt “cheap” out on parts as I am not even done with the build i want. Eventually i will change the oil pump and in that case the tc will be changed also.
you DO NOT have to drop the oil pan to do the TC, all that needs to come of is the timing cover and oil pump, and by the way the I think I got mine for $55 a melling M295 is a much better oil pump then stock, normal pressure and volume, my idle pressure HOT went up 5 psi and 5 psi overall, think you better find a new mech if he thinks you got to drop the pan. that statement makes me wonder about the "2000 hp vettes" statement, the build is not that expensive when you do the work yourself, I don't think I had $750 in mine, lets see... cam, TC all gaskets and seals, oil pump, springs, valve seals, tool steel retainers and locks, cam gear got the crank gear too, but couldn't get the old one off, drill rod to keep the lifters from falling.
