Best fluid for TR6060
Old Nov 4, 2017 | 11:49 PM
JetstreamGS's Avatar
JetstreamGS
Default Best fluid for TR6060
Looking to replace the fluid in my 6060. What's the best stuff for it? D4? Torque Drive? What are you folks running?
Old Nov 4, 2017 | 11:52 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Torque drive
Old Nov 5, 2017 | 12:16 AM
sabersaw30's Avatar
sabersaw30
Originally Posted by C U IN REARVEIW
Torque drive
Yep that is what i used!
Old Nov 5, 2017 | 04:45 AM
User Omega's Avatar
User Omega
RPM transmissions suggests Royal Purple Syncromax. I run it. 7k+ rpm shifts no problem. Stock trans.
Old Nov 5, 2017 | 09:02 PM
CMY SIX's Avatar
CMY SIX
BG products Syncro-shift II part# 792 made to replace ATF in manuals. you will not believe how QUITE the car will get
Old Nov 6, 2017 | 01:21 PM
Tech's Avatar
Tech
I used the Joe Gibbs stuff for a few hundred miles. Seemed fine. Unfortunately, my clutch was dragging and toasted that transmission. My trans was repaired by RPM and they recommended RP Synchromax, so that's what I'm using now. Trans shifts better than it ever has.
To Best fluid for TR6060
