Two pc Brake Rotor?
Old Dec 2, 2017 | 10:02 AM
ROUTE 66's Avatar
ROUTE 66
Default Two pc Brake Rotor?
Looking to replace my front brake rotors with 2 pc rotors.[07 Z06] Thinking of using Stop tech aero-rotors. Have any of you used there equipment? Did you like it? Or should I use something else. What would you suggest. Thanks for your help!
Do not track my car but want to cut weight and have good brakes . Thanks again.
Old Dec 2, 2017 | 10:39 AM
Unreal's Avatar
Unreal
Lot of money for a little weight. I run the 2 piece zip rotors. They are nice, but hard to say worth the money. Stock rotors with good pads stop great and will put a hurt on any street tire and easily activate the ABS.
Old Dec 2, 2017 | 10:44 AM
ROUTE 66's Avatar
ROUTE 66
I haven't given any thought to the ABS. Do people have a problem with ABS when using aftermarket brake rotors
Old Dec 2, 2017 | 12:16 PM
HOXXOH's Avatar
HOXXOH
Unreal was referring to the street tires lacking grip, which can activate ABS. A different brand of rotor won't shorten stopping distance, but better pads and tires will.
If you want to cut weight, try draining excess wiper fluid.
Old Dec 2, 2017 | 12:18 PM
Unreal's Avatar
Unreal
Or swapping to base brakes which are even lighter and still have more than enough to stop the car and activate the abs.
Old Dec 3, 2017 | 02:11 PM
timd38's Avatar
timd38
No problem with the ABS. The hubs have the ABS sensor in them.
Old Dec 3, 2017 | 02:12 PM
timd38's Avatar
timd38
Plus Z06 brakes are junk. The pins freeze up, odd ball pads, etc. I put Wilwoods on my car about 8 years ago. Had Z06 brakes on for about a month.
To Two pc Brake Rotor?
