Torque tube couplers
Old Dec 4, 2017 | 09:16 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default Torque tube couplers
Pulled driveline out to do clutch....thought the coupler was on the end of torque tube.....how to get to them?
Old Dec 4, 2017 | 01:05 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
You have to take the trans off and it disassembles from the rear and pulls out.
Old Dec 4, 2017 | 02:53 PM
Unreal's Avatar
Unreal
Remove the huge SOB snap ring on the other end, then the drive shaft will slide out with the couplers/bearings/etc.
Old Dec 4, 2017 | 04:23 PM
C U IN REARVEIW
Only 30k miles on car(8k at 585whp).....worth looking?
Old Dec 4, 2017 | 05:17 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Always worth checking if that close already. My original ones were still like new when I changed them but never know.
Old Dec 4, 2017 | 08:58 PM
C U IN REARVEIW
I've read/heard that 1 solid and 1 poly are the way to go...?
Old Dec 4, 2017 | 09:02 PM
CMY SIX's Avatar
CMY SIX
I'm going poly, it would seem a little forgiveness might be good, but even if you go rubber at least their new, what cha got an 08? their ten years old.
Old Dec 4, 2017 | 09:05 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I went with ZR1 parts. But that calls for a custom driveshaft. When it comes to drivetrain I go with what Jeremy at RPM suggests.
Old Dec 4, 2017 | 09:10 PM
CMY SIX's Avatar
CMY SIX
can't go wrong there, I won't have the RWHP that you will but I have a ZO6 drive shaft, poly couplers and SKF bearings, when I pull every thing for the new LS7 clutch. your taking a short vacation up here when I decide to do it...... right?
Old Dec 4, 2017 | 09:16 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
LOL. Judging from your posts I would rather vacation alone in the artic.
Old Dec 4, 2017 | 09:18 PM
CMY SIX's Avatar
CMY SIX
man o'man where's the love?
Old Dec 6, 2017 | 10:12 AM
darknit's Avatar
darknit
I put in a DSS 3" driveshaft with one solid and one DSS poly... so far so good...
Old Dec 6, 2017 | 11:17 AM
TTZ06VETTE's Avatar
TTZ06VETTE
I did the same but with one solid and one hard rubber with good results.
Old Dec 6, 2017 | 12:02 PM
FNBADAZ06's Avatar
FNBADAZ06
I had the same...solid rear but OEM front. The new OEM front recently took a dump, so I'm now installing the DSS poly in the front.
Old Dec 6, 2017 | 03:34 PM
TTZ06VETTE's Avatar
TTZ06VETTE
I was considering doing the same but was warned that the poly longevity was actually worse than OEM.
Old Dec 6, 2017 | 03:56 PM
FNBADAZ06's Avatar
FNBADAZ06
I has originally thought of upgrading to a ZR1 prop shaft and thicker couplers, but that requires a different torque tube for my (2006).
My only other option is a DSS couplerless driveshaft. I had hoped that a solid rear with an OEM front would be sufficiently strong to handle my 600 RWHP during drag race launches, while also eliminating the issues of NVH that some have reported when using solid or poly couplers.
Old Dec 6, 2017 | 09:19 PM
C U IN REARVEIW
Man idk.....This is not something I want to do again anytime soon.....?
To Torque tube couplers
Old Dec 6, 2017 | 09:51 PM
MTPZ06's Avatar
MTPZ06
How are you using the car? Street, street/strip, etc.
Old Dec 6, 2017 | 09:52 PM
doomi's Avatar
doomi
This has honestly been a good informative thread for me. But this is the funniest post I've read in a while.
Old Dec 6, 2017 | 10:00 PM
C U IN REARVEIW
100% street...will be in high 600's hp
