If any one has a 2005, could you tell me what order the wires are in on the cam sensor connector where it come out of the engine harness and plugs into the cam sensor jumper harness? It is right above the front spring, drivers side, and to the left of the balancer. Terminal A is towards the front, Terminal C is next to the engine. I have an early 2005 which has different colors than a car built 6 months later I looked at.
-or-
if you have a 2005 shop manual, it is connector C103 GM S.I. for some reason does not show it and 06-07 show different colors. I have brown, pink/black stripe, white/brown stripe wires.
-or-
Here is the connector with pin and wiring color designation for the 6.0 l 2005 Corvette
It has Orange ; Pink/Black ; White / Brown wires.
Sometimes orange looks like brown
Thanks. Where did the top picture come from? Other than the pnk/wht, the colors I have are different in the first picture. The second is correct for what I have- this is the jumper harness in side the metal shield.
Which one in the wiring diagram (2nd picture) is the same as yours?
The top pic is the connector for the Camshaft (CMT) sensor and is the connector is the exact same as the bottom pic.
I also have the connector pic for the other camshaft (CKP) position sensor if you want to see that as well.
I went through the wiring diagram for the cam sensor from the pcm to connector c103. What the shop manual shows orange, I have brown- 12 volts term A, pink/black is low reference both in the wiring diagram and on the car, terminal B, Brown/white is my white/black, terminal C, cam sensor signal. With that solved, not to go to why it does not run.
