E85?
Later sense I was going for 550 or better wheel I got a Walbro 450 lph and 72 lbs injectors tho 60 may do.
That's all I did the rest of the fuel system is all stock.
About 2 years later the in tank fuel pressure regulator stop working so if you go in there to change fuel pump upgrade the pressure regulator as well if they make an aftermarket one.
Not wanting to drop the tank again I installed a small external pressure regulator using the schrader valve at the end of the ds fuel rail for a return style fuel system.
With the flex fuel sensor in place, as the E rating changes, the sensor will allow the ECM to compensate for the changes in the pump fuel. Hence there is already a flex fuel tables in the ECM programming, so all that is needed it to install the sensor installed, and turn the tables on in the tune to use them during the tune.
DSX Flex Fuel kit $300
Good dyno tune $500 ish
I run a little Lucas ethanol treatment to keep the system lubed. All good.
Cam, heads, headers, xpipe and intake. 499.5whp. It is a GS though so has the Z06 fuel pump.
Hence with NOS, your going to be spraying both NOS, and more fuel, and depending on the HP you plan on achieving, the stock fuel pump may not be able to keep up with the demand.
And just a FYI, with NOS playing the once in blue moon thing ,it not a mater of if the engine is going to blow, but when isntead.
Hence with NOS, you create more heat, and if the piston ring gaps have not been increased, just a mater of time when the rings to to zero gap from the heat, they bind to the side of the cylinder, and snap the head off a piston isntead.
So to build a motor for NOS, you have to increase the ring gap for the upcoming heat for when on NOS, which means that when the motor is not run on NOS/subject to the increase head, your giving up power/compression instead.
You can expect an 8% gain running E85 on a naturally aspirated engine, and about 15% if you have a turbo or supercharger.
Douglas in Green Bay
https://www.corvetteforum.com/forums...rs-vs-e85.html
