Lifter wear - Does this look normal?
Old Jan 5, 2018 | 08:07 PM
CI GS's Avatar
CI GS
Originally Posted by Havoc40
Sorry for the backorders on 2110's!!! They've been going out the door as of this week, with plenty behind it.
There's a few potential problems, but hard telling without the parts in hand. How's the cam look?
Thanks. That is good news. I really want to get my hands on a set of those, even if I have to wait an extra week to put the engine back together. I’m thinking of going with the 2110R lifter.
Can you say roughly what the difference in length of the pushrod would be going from the LS7 lifter to either the 2110 or 2110R, all other things remaining equal?
I note the Rs have a special retainer that sets the plunger 0.035” down into the lifter to reduce travel vs. the standard 2110, but are the lifters themselves shorter/longer than the LS7?
Old Jan 5, 2018 | 08:17 PM
CI GS's Avatar
CI GS
Originally Posted by realcanuk
Spring pressure would vary with installed height, but I'd assume that was calculated and checked.
Nope. I installed the kit as I received it from VR. As I was installing it on a hydraulic cam street engine with <2,500 miles that had never had a valve job, etc., I figured that I could get away without being that **** and shimming each spring to get absolutely exactly matched installed height, lol.
I didn’t have any shims anyway.
But if it’s excessive spring pressure that caused this, then what the hell are those guys with the HD springs (like the ones I just today received from BTR) and bigass cams with 1.8 ratio rockers doing? After all, this is the “LS7” lifter, so I’m sure that there’s lots of guys running much more spring pressure on their LS7 setups.
I think you hit the nail on the head earlier with the damn Mobil 1.
Old Jan 5, 2018 | 08:23 PM
CI GS's Avatar
CI GS
Originally Posted by old motorhead
I've been running Euro spec Mobil 1 0w40 in my LS3's. It has much higher zinc and phosphorous levels than the other Mob 1 oils.
I believe Lingenfelter recs using 15/50 Mob 1 in anything they supercharge. Just food for thought. I'd use the 0/40 in any stock short block LS3 and whatever the engine builder recommends for a "built" engine.
I’ve been thinking of switching to the 0W-40, which I can get from Napa here. It is quite a bit thicker than the 5W-30 M1 at lower/startup temps though, even though it’s 0W vs. 5W. That looney oil grading **** drives me up a wall.
Old Jan 5, 2018 | 08:25 PM
CI GS's Avatar
CI GS
Umm, don't start that. Andy's the only one who's always right And he's off somewhere in ZL1 Camaro land.
And personally, I'd get Pat G to spec you a cam. Not much of a fan of the really wide LSA blower cams. Especially with big duration valve events like BTR's Stage III.
Yeah, well, you’ve taken over from Andy, it seems...
Wait, I swear that you told me once I should ask Brian for a Stage III cam. You really are a terrible influence.
Old Jan 5, 2018 | 08:32 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
All I can say regarding that is I am running the BTR 650 springs, 1.82 roller rockers and the morel linkbar lifters. The cam is from comp. had the heads off last winter and looked closely at the cam and lifters. Everything looked as new. I'd say maybe 5000 miles at most. I'm pretty sure the lifters have a bigger wheel but I don't think that contributes. Springs were checked and installed to proper heights.
I'd agree that most likely contributor might be the oil. I remember reading they have constantly reduced the zinc content over the years.
Old Jan 5, 2018 | 08:53 PM
CI GS's Avatar
CI GS
Originally Posted by Caveman74
I have never been a fan of Mobil 1.
Me either, to be honest. I only started using it after I bought the Vette in 2013. Before that, I always used either Valvoline racing synthetic oil or Redline.
Old Jan 5, 2018 | 08:58 PM
CI GS's Avatar
CI GS
Thanks for that. I think the bigger wheel helps more with side loading of the lifters at the bottom of the bore.
It must be the oil or the cam core causing a problem. The cam looks perfect from what I can see. I’ll inspect that properly too.
I have a case of Mobil 1 in the garbage that I’m going to give away tomorrow!
Old Jan 5, 2018 | 09:25 PM
Chiselchst's Avatar
Chiselchst
Amsoil makes that Zrod 10-30 (and like a 20-50?), which is high in zinc (ZDDP). As are the M1 racing oils, and their 15-50. I've even entertained the motorcycle oils as they look good on paper (HT/HS, ZDDP, etc).
Unreal is a big fan of the ZRod...
(The ZDDP level is one controversial issue, LOL)
Old Jan 6, 2018 | 12:12 AM
CI GS's Avatar
CI GS
Yep, I’m familiar with the Amsoil ZRod oil. I also recall that the Motorcycle engine/wet clutch Mobil oil was very popular with the I/O boating guys on offshoreonly.com for that very reason: it was high in ZDDP. And there’s no kind of engine that gets the stress of an offshore race boat: high load, high rpm, loading and unloading as the boat leaves and re-enters the water, whilst being pitched around in the waves. If an oil stands up in that environment, it should stand up in your car. Nothing compares to that. The picture below will give you an idea of what I mean (yeah, I know it’s completely off-topic, but that’s how we roll up in here). That’s me and a friend of mine running at about 85 knots in the ocean a few years back in our now defunct annual poker run. That shot was taken from a helicopter, just a few minutes before we hit a wake from a boat we were lapping and spun out on the last turn and nearly flipped it. What a rush that was. Yeah, drag racing in a car is boring **** compared to that.
Old Jan 6, 2018 | 12:22 AM
Chiselchst's Avatar
Chiselchst
Holy crap Sammy, damn thing looks like it could shoot down an F16!
And you still have kidneys, too? LOL
Piston/recips on the water get brutal treatment, running ***** out all day - unloaded/loaded HARD like you said. Is that a surface drive? Arneson - inventor of a surface drive local to me - switched from piston engines to turbines as they are meant to operate at 100% all day...after he kept blowing engines.
You're one brave hombre brother!
Okay, sorry to digress...
Old Jan 6, 2018 | 12:36 AM
z06scentair's Avatar
z06scentair
Let me point out, while Randy has joined the thread make sure you measure the bore diameter prior to ordering.
The last set I purchased created some questions on my end after the install. my car has 20k miles and always had 32-38 hot idle OP. After the Lifter change my OP dropped to 22-24 hot idle. The 2110 lifters measured .8420" and my factory lifters measured .8423" - .8424".
At the end of the day that .0003" - .0004" additional clearance resulted in -10psi OP at hot idle.
Has it created any issues in 10k miles? Nothing that I can tell, however I would sleep easier if I had measured and had them ground specific.
I'm a firm believer in Johnson lifters and I'm confident Randy can grind you exactly the size to meet the factory tolerances within a micron.
Only way to tell the extent of the roller wear would be to run a profilometer across several measuring the Ra. While they're out change them.
I've ran the LS7 lifters in many engines and have not had issues. One thing that is certain, the 2110's are not as audible as the LS7. Must be better quality correct?
Old Jan 6, 2018 | 05:41 AM
CI GS's Avatar
CI GS
This is all very good info. Thanks very much for this.
I’m thinking that with the little extra lifter bore clearance, your camshaft and lifters should be getting some extra oiling right where it’s needed. That’s the silver lining there, I guess.
What’s your oil pressure like at WOT/max rpm? I have a Melling HP/HV oil pump, which should help. I was getting ~40 psi at idle and ~75psi at 6500+rpm at operating temps, iirc.
Old Jan 6, 2018 | 05:56 AM
  #33
CI GS's Avatar
CI GS
Yep, surface drive, but not Arneson. That guy is a legend. The guy who owns this boat has a 38’ cat with twin Whipple blown 1500hp motors that has run 190+mph with Arneson drives.
The boat in the pic is an FB hull, designed by Fabio Buzzi, undisputedably the best race boat designer ever. It’s powered by a Seatek twin turbo diesel (which can crank out up to 1450hp) with a Trimax drive, all designed by Buzzi. The whole thing is designed to enable it to pierce a wave and return to the surface. Lots of crazy clever stuff in the design. The rear wings are what kept it from barrel rolling when we spun it out and probably saved our lives, because we found out after that there was no oxygen in the life support system.
Yeah, I’ve done some crazy **** in my time.
Okay, my bad, I’ve digressed again. Back to the lifters...
Old Jan 6, 2018 | 06:10 AM
  #34
rajahhindi's Avatar
rajahhindi
Beautiful shot. I bet that takes pride of place in your bar pics?
Old Jan 6, 2018 | 09:25 AM
  #35
CI GS's Avatar
CI GS
Hell yeah. That’s the screen saver in my desktop at work, just to remind me that there’s life beyond the drudgery of daily labour...
Old Jan 6, 2018 | 09:52 AM
  #36
irok's Avatar
irok
your issues are going to get worse with the smaller diameter lifters
Old Jan 6, 2018 | 10:08 AM
  #37
CI GS's Avatar
CI GS
Get worse, how? What smaller diameter lifters? I’m not planning to buy smaller diameter lifters. We were talking about a difference in diameter of .0003-.0004”, which would mean more lifter to bore clearance and slightly lower hot oil pressure. I can’t see how either of those things could have contributed to the slight galling of the rollers on my lifters, so how would the Johnson lifers make my issues worse? Am I missing something here?
To Lifter wear - Does this look normal?
Old Jan 6, 2018 | 10:37 AM
  #38
irok's Avatar
irok
have seen a few posts on here reporting op drop into 20-25 psi range with those lifters.my hot oil pressure runs 40-75+ with stock pump and I'm more comfortable with 40 psi hot idle.with .0003-.0004 difference in diameter where did the 20 psi go?
Old Jan 6, 2018 | 11:01 AM
  #39
CI GS's Avatar
CI GS
Okay, understood. I don’t want a drop in oil pressure either, although my car has much higher pressure now with the Melling HV/HP pump than it did with the stock pump. I thought the pressure drop that folks were reporting on the Johnsons was for the pin oiler version, until z06scentair posted his very useful advice on here.
Old Jan 6, 2018 | 11:22 AM
  #40
irok's Avatar
irok
my engine builder/machinist is the best I have met in 48 years.one of my engines has 27 seasons on it and never run anything but Mobil 1 15-50. I put a lot of weight in anything he tells me
