Service Active Handling - Steering Wheel Position Sensor
Old Jan 9, 2018 | 08:02 PM
Rudy88's Avatar
Rudy88
8th Gear
Default Service Active Handling - Steering Wheel Position Sensor
Hi guys, car is a 2010 base and when I pulled my steering rack to install my supercharger I had some trouble lining the shaft and rack up. Now that everything is back together the steering wheel is slightly off center when straight and is triggering the service active handling code. Will an alignment fix this?
Old Jan 9, 2018 | 09:00 PM
RicK T's Avatar
RicK T
Can't say for sure but the column is likely out of rotational alignment.
Check this discussion for info that may help:
https://www.corvetteforum.com/forums...post1596230409
