Need your help. I own a 2005 c6 z51. The problem I have is out of the blue very random. The car will not start. Nothing when you press the button not even a click. All lights horn alarm work fine....
It's just a stab in the dark, if an automatic, will it let you turn to Accessories(pushing down on start button)? if so put it in neutral and see if it'll start then.
You didn't give us much info. Mileage? Transmission? Does it have a telescopic steering column? Have you checked battery cables?
you double posted question.scroll further down page for possible issue
