2008 stuck in accessory mode
Old Feb 7, 2018 | 08:08 PM
bigblueman's Avatar
bigblueman
Default 2008 stuck in accessory mode
NEW BATTERY
NEW IGNITION SWITCH
Car starts fine, but when I press the ignition switch , to turn the car off. The car shuts off, but gos in accessory mode and kills the battery.
Thanks in advance......
Old Feb 7, 2018 | 09:11 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Switch
Subscribed. Curious about answer.
Last edited by 2008 Corvette; Feb 7, 2018 at 09:19 PM. Reason: Curious about answer.
Old Feb 7, 2018 | 09:17 PM
bigblueman's Avatar
bigblueman
Old Feb 7, 2018 | 09:19 PM
Dano523's Avatar
Dano523
Originally Posted by bigblueman
NEW BATTERY
NEW IGNITION SWITCH
Disconnect the battery cables, touch the positive cable to the negative cable (both off the battery) to fully drain the electrical devices in the car to do a full hard reset, reconnect the cables to the battery, then try the button again.
If you still have the problem, then you have a faulty ignition switch that will need to be replaced.
Old Feb 7, 2018 | 09:24 PM
bigblueman's Avatar
bigblueman
Ignition switch is new
Old Feb 7, 2018 | 10:36 PM
Dano523's Avatar
Dano523
And could be new defective as well.
If you want me to walk you throw pulling it apart to fix the problem, I can. The short version is the rocker front piece can be snapped off, that allow you to get to the internal contact parts to make sure that they have been seated correctly, and stayed seated correctly when the front rocker panel was snapped in place.
But since it new, and could be new defective (whole internal parts problem), then send it back to be replaced if hard resting the car is not solving the problem.
Now the Million Dollar question and where you have the same problems with the old switch, since I can't see both being same defective and causing the same problems.
Old Feb 8, 2018 | 04:10 AM
bigblueman's Avatar
bigblueman
I will try battery drain.
Old Feb 8, 2018 | 08:06 AM
bigblueman's Avatar
bigblueman
anybody
Old Mar 6, 2018 | 09:18 PM
bigblueman's Avatar
bigblueman
ttt
Old Mar 6, 2018 | 09:20 PM
bigblueman's Avatar
bigblueman
It is not ignition switch or battery, It seems when you shut the car off it gos in ACC mode and will not time out. Kills the battery.
To 2008 stuck in accessory mode
