E85 tune
Old Feb 11, 2018 | 09:38 PM
simnova6's Avatar
simnova6
Default E85 tune
hey guys I currently have intake and x pipe. Was wondering if it's worth to go with E85 and tune. Not installing headers or anything else. Or it's not worth the upgrade? Thanks for any input
Old Feb 11, 2018 | 10:55 PM
Dano523's Avatar
Dano523
The ECM already has flex fuel tables, so what you need to do first off, if to install the flex fuel sensor into the fuel line so the tables can be turned on and used in the tuning.
From here, the car is tuned using the Flex fuel tables as well, and if you do need to run the car on standard petrol, or the E rating is lower in the fuel from the pump fuel your using, the senor picks this up, and the car runs correctly as well.
As for X pipe and new intake, not enough difference on petrol, so the car itself will compensate for the changes. By adding the flex fuel sensor so you can run E85, will pick up some power on that fuel.
When you install headers and just running petrol to start with , the long tube headers will scavenge exhaust a great deal more, and although the ECM will compete for such during close loop mode, when you go to WOT/ the car is running on all tune since it's goes to open loop, this is where the motor will be running too lean instead.
As for the down side to E85, you will burn about 30% more of it per mile, then you will of petrol instead.
Old Feb 11, 2018 | 11:09 PM
Denis_C6-Z's Avatar
Denis_C6-Z
I don't think it's worth it right now.
Old Feb 12, 2018 | 08:16 AM
simnova6's Avatar
simnova6
That car already burns crazy amount of fuel lol. Can't even imagine on E85. Thanks for the input guys. I may just hold off and do all at once. Headers, pulley, etc.
Old Feb 12, 2018 | 08:18 AM
Denis_C6-Z's Avatar
Denis_C6-Z
Do you have a ZR1 or a Supercharged Engine?
Old Feb 12, 2018 | 08:35 AM
simnova6's Avatar
simnova6
Originally Posted by denis_c6-z
do you have a zr1 or a supercharged engine?
zr1
Old Feb 12, 2018 | 07:40 PM
KB9GKC's Avatar
KB9GKC
zr1
Hello,
ZR1 gains about 70Hp on E85 with tune!
Douglas in Green Bay
Old Feb 12, 2018 | 07:49 PM
Denis_C6-Z's Avatar
Denis_C6-Z
Yes! That's why I asked what you had. If you have ZR1, helk yes put it on E85!
Old Feb 12, 2018 | 07:53 PM
simnova6's Avatar
simnova6
Awesome guys. That's what I wanted to hear. I may just pull the trigger
Old Feb 12, 2018 | 07:54 PM
simnova6's Avatar
simnova6
What flex fuel sensor should I get ?
Old Feb 12, 2018 | 07:58 PM
simnova6's Avatar
simnova6
Is the DSX kit any good ?
Old Feb 12, 2018 | 09:58 PM
xBoostx's Avatar
xBoostx
Not sure why you don't want headers IMO you should reconsider, regardless of what you end up doing here's what I did when I first got my auto '11 GS;
Vararam cold air intake ported the throttle body and the intake manifold because intake was out I took the opportunity to match port the heads intake runners and just filled tanks with E85 and tuned it.
With absolutely no other mods the dyno revealed 404 whp and 397 tq, now the engine was running out of breath at 5500 rpms due to restriction of factory exhaust manifolds so adjusted shift points to 5500 the tuner told me the car's running amazing he was darn rite, do recommend this.
Old Feb 13, 2018 | 12:13 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Yep it's pretty much the gold standard.
Old Feb 14, 2018 | 03:18 PM
simnova6's Avatar
simnova6
cool. will get the kit and getting the car done next friday. will post pics. and dyno results
Old Feb 16, 2018 | 07:26 AM
simnova6's Avatar
simnova6
How many hours of labor should A shop charge me to install this flex fuel sensor kit ?
Old Feb 17, 2018 | 07:56 PM
Turbo2L's Avatar
Turbo2L
2 hours would be fair, but if they don't work on C6s everyday then maybe 3-4.
Old Feb 18, 2018 | 09:38 AM
KB9GKC's Avatar
KB9GKC
Old Feb 18, 2018 | 09:20 PM
Unreal's Avatar
Unreal
2 hours is a stretch.
To E85 tune
