18" square setup
Old Feb 19, 2018 | 10:29 AM
GaragedLS2's Avatar
GaragedLS2
Default 18" square setup
Anyone with a square 18" wheel setup on their base car? I'm looking to go square possibly but interested to see what width wheel I can run with what size tire. I've heard of 19 x 9.5 fitting up front so curious to see if 18x10 would work on a square setup?
Old Feb 19, 2018 | 10:37 AM
jaredtxrx's Avatar
jaredtxrx
In for answer, but I don't think it will work.
Old Feb 21, 2018 | 06:52 PM
R_W's Avatar
R_W
I would be interested in this as well for a road racing / track / HPDE application. I have had this same question for a while, but not researched seriously enough to come to any kind of conclusion.
Maybe someone in this section would have an answer for us...
https://www.corvetteforum.com/forums...roadracing-23/
Old Feb 21, 2018 | 07:15 PM
old motorhead's Avatar
old motorhead
If you're considering the same sized tire/wheel combo on all four corners, you'll need to turn off all of the nannies all of the time. Plus, it's going to ride low in the rear relative to the front. No matter the rim size, I'd still try to maintain the stock front to rear diameter ratio.
Old Feb 21, 2018 | 11:05 PM
hungryhippo's Avatar
hungryhippo
You can run 18x10.5 all around but different offsets are required for the front and rear.
Old Feb 22, 2018 | 07:52 AM
lawson1603's Avatar
lawson1603
You can it will work.
https://www.corvetteforum.com/forums...ire-setup.html
TSW will also work.
https://www.corvetteforum.com/forums...t-of-a-c6.html
Old Feb 22, 2018 | 07:06 PM
GaragedLS2's Avatar
GaragedLS2
Those C5Z 10.5s up front seem to stick out quite a bit. I wonder what the offsets were on those TSW's. Hard to tell since its a distant photo but the car seems to be relatively low and the tire looks like its inside the wheel well.
10.5 w/ 295's would be great. Really dont want to spend the money on an OEM widebody but it seems that may be the best option to run a nice sized square setup.
Old Feb 22, 2018 | 07:20 PM
lawson1603's Avatar
lawson1603
I think those wheels only come in one offset for the vette in 18 and their 65.
Old Feb 24, 2018 | 07:24 PM
Dirk Miller's Avatar
Dirk Miller
Default square wheels
pm to be sent
Old Oct 26, 2018 | 09:50 PM
Sarge5052's Avatar
Sarge5052
Default It Works! 18x10.5 square set up with PICS.
Meatier than expected. The fear sets in they wont fit.
Difference in rear Bridgestone RE11s 285 series to Toyo RRs 315 series. Toyos are substantially shorter front and rear.
Rear test fit. Inside lip looks like it won't clear without cutting, but does on the ground.
Test fit front. Same concerns but it works on the ground.
On the ground. Front actually tucks in a bit, rears are jjuusstt out a bit from flush (Don't care.). Pardon the dust!
Rear quarter view.
Booty.
So I'm going to go ahead and bring this back from the dead from earlier this year, so all information is in one place. I've been referencing this thread heavily and a couple other older ones for the last few weeks IOT get ready for Auto Club Speedway Roval Nov 4th/track days. Basically put all my faith in the forum and it worked out great so far with no real clearance issues. No rubbing although it was just an easy drive on it so far.
  1. TSW Nurburging or Interlagos will work. 18X10.5 65et all around.
  2. The Toyo Proxes RR will work fine. 295 30 18 fronts, 315 30 18 rears. You could go 295 all around for tire rotation purposes.
Alignment is done and super conservative right now PFADT street specs, but plan on at least -1.7f, -1.0r camber without issue and go from there.
Car is a base body 2005 C6 with F55 stock suspension. My inner fenders were/are the worst, and I thought I'd need spacers or maybe even cut into them; not the case. They have been chopped a bit for boost etc on the bottom but that has only made them worse. I took lots of pics for you guys since there's only like, ONE decent picture on the forum that I put all my faith and trust in. Now no one else will have to lose sleep while waiting on their shipments from amazon and tirerack!
Old Oct 27, 2018 | 06:57 AM
sccaGT1racer's Avatar
sccaGT1racer
Yes you can run 18 square on 10.5 speedline rims. Ive used both 315 and 295 with this setup. The 315 size is faster. If your going to order custom rims get 18x11 with the proper offsets.
Old Oct 27, 2018 | 07:46 AM
tslsa28's Avatar
tslsa28
I ran the 18x10.5 TSWs on the rear of my C6 track car and they stuck out just enough for the outside of the tire to touch the inner fender when the suspension was compressed on the race track. Just check your rear inner fender for rubber at the end of your day at the track to be sure you're ok.
Old Nov 11, 2019 | 11:55 PM
Jasontrantham's Avatar
Jasontrantham
Default More pics of front please - how much does it stick out?
Can we have pics of the front.
Rear quarter view.
Booty.
Old Nov 12, 2019 | 03:16 PM
Sarge5052's Avatar
Sarge5052
Default Front pics Nov 2019
Front pics from last weekend. Fronts don't stick out and if you have camber plates the rears won't really stick out either (but near stock camber in pics).
Fitment on stock shocks.
Old Nov 12, 2019 | 07:21 PM
Jasontrantham
Default Thanks
Great pics. They look good. Was worried they would stick out but they look pretty flush to me. Thanks again!!!
Old Nov 13, 2019 | 08:23 AM
davidfarmer's Avatar
davidfarmer
Works fine, plenty of us track oem c5 10.5 rims all around. I ran them before and after adding wide fenders
Old Nov 13, 2019 | 08:31 AM
davidfarmer
Wide body
Skinny body
To 18" square setup
Old Nov 13, 2019 | 02:05 PM
R_W's Avatar
R_W
I like what you did there, David.
I had this vision of 18 x 11 on all 4 corners with help from the wider front fenders from Supervettes (adds 1.5" per fender over a wide-body C6, if memory serves) on a C6 Grand Sport, but offsets become an issue (I'm a wheel sizing idiot and have no idea what I'm doing when it comes to fitment). Who knows where this wild-hairbrained-scheme will end up...
Old Nov 14, 2019 | 06:14 PM
davidfarmer
start with known rims then go from there. The calculations are easy, but I prefer seeing what works, then adding width inside/outside once I know for sure.
I have Z06/GS rims and a set of CCW's also, even some base wheels laying around. Always pretty easy to find a starting point.
Old Nov 14, 2019 | 07:18 PM
Jasontrantham
Default Will try a set
I am going take my 18x10.5 +65 TSW’s and put them on the front. If they look ok, I am going for it. Need that extra 1” of tire up front.
