Cam Question A6 trans
I understand with a torque converter, the oil acts as a disconnect between the transmission and the engine in that at low rpm's, the oil will essentially disconnect the engine from the transmission so you can roll to a stop (for example).
If my understanding is correct, then using a stock converter, at 1400 rpm's the engine and transmission are for all intent and purposes "locked" (but not like the locking in gears 3 - 6). So with slippage, you get more heat into the oil which will have to be dealt with sooner or later.
So with big cammed cars that won't idle below 1200 rpm's, a 1400 rpm torque converter could be a real pain in the rear for drive-ability, plus you would end up with a heat problem with the transmission oil too.
So is my understanding correct so far? And what does "flash" mean?
Thanks in advance.
Dave
On the 440 Ci LS7 06 GTO with a 3600 pro Yank sees 5400 every time.
Higher power higher rpm flash.
Honestly Mike all these high stall converters produce a lot of heat real quick not sure is a good idea considering the use suggested by sign on your car door
I encourage you to do your own research rather than just rely on the answers you get on the forum. A good start is to check out Yank's website, as it has a lot of good, basic information.
There are quite a few good converter companies out there, but two I see constantly recommended for performance applications are Yank and Circle D.
