02 censor question
Old Feb 25, 2018 | 06:15 PM
Oscarito's Avatar
Oscarito
Default 02 censor question
I’m running kooks long tube with high flow cat x pipe, do I need to install my rear 02 censor if I’m getting it tune once my “bolt on” build is complete? Can I just plug the 02 censor holes?
thanks
Old Feb 26, 2018 | 01:42 AM
Dano523's Avatar
Dano523
thanks
The pre o2 sensors (right before the end of the header collects (will still be used, while the post 02 sensor after resonator or high flow cats will not be use/turned off in the tune, and in fact, these O2 sensor holes in the X pipe get plugged instead.
So make sure that you pick up extension cables so you can plug the pre-02 sensor cables into the Pre-02 sensors on the header pipes.
The post O2 sensor connects can just be tucked up out of the way so they don't get melted by exhaust pipes, since your not going to be using these connectors.
Old Feb 26, 2018 | 11:34 AM
Oscarito's Avatar
Oscarito
Thanks, I have the headers already installed with the o2 sensors connected. I’ll install my catted x pipe without the o2 connected and plug in the holes.
Old Feb 26, 2018 | 02:55 PM
Dano523's Avatar
Dano523
Understand what the OS2's are doing and what ones you need.
The front pre O2's sensors are used for the motor when the car is running in closed loop to adjust the AFR to 14.7.
When you go to WOT, the car goes into open loop, does not use the pre-O2 sensors instead.
The Post O2 sensor are just monitoring the cats alone, and looking for a differential reading from the pre-02 sensors (are not as all to adjust the motor to 14.7AFR).
With headers, and even high flow cats after the header collectors, your moving the cats too far from the heads themselves (your heat source), so even through the high flow cats are working, they are not working as efficiently as the stock Cats when they were much closer to the head. So the post O2 sensors will not have a big enough differential reading from the Pre 02 sensors, will end up with codes (cats not working as efficiently as the stock cats).
So in the tune, the post O2 cats are turned off, which solves the problem of high flow cats not working effectually enough as the OEM cats codes being thrown.
Old Feb 26, 2018 | 08:00 PM
Oscarito's Avatar
Oscarito
Thanks for the information🤜🏻
Old Mar 5, 2018 | 07:52 AM
irok's Avatar
irok
better to leave them plugged in any way even though turned off in tune so they will pass visual for emissions.
Old Mar 5, 2018 | 11:39 AM
Oscarito's Avatar
Oscarito
I live in California, so just my intake is already illegal. I need to get around it lol
To 02 censor question
