Passenger Seat is stuck in full back position and can't get it to move forward to get at the rear seat bolts to remove seat. Is there a way to manually release the seat forward so I can get at the bolts??
I should have been cleared i'm sorry. I have power but , both lumber support switches work fine just the front rear seat adjust along with raise lower do not work. The seat motor will run for a second then shut off and motor gets hot. I read in another post where the seat was removed, contacts cleaned and then re lubed and seat worked fine. At this point I just cant get at any of the guts.
Passenger Seat is stuck in full back position and can't get it to move forward to get at the rear seat bolts to remove seat. Is there a way to manually release the seat forward so I can get at the bolts?? I have power but , both lumber support switches work fine just the front rear seat adjust along with raise lower do not work. The seat motor will run for a second then shut off and motor gets hot. I read in another post where the seat was removed, contacts cleaned and then re lubed and seat worked fine. At this point I just cant get at any of the guts.
After much seeking I am of the opinion that there is no way to manually move the seat forward to get at the rear bolts to remove the seat to look at the guts and try and figure out why seat was stuck in lowest position all way back! Since it had power and after reading directions on how to remove seat switch (was easy) I took a chance and purchased a new switch for 125.00 (got it from dealer as I was afraid to purchase a used one) and I am happy to report that the seat is now working fine. Glad It was just a switch!!
