C6 Tire Pressure Valve
Old Apr 3, 2018 | 12:56 PM
blueflame1954's Avatar
blueflame1954
Default C6 Tire Pressure Valve
I've been away for 5 months and my 2006 Corvette has been in my carport (Central Virginia).
Tried to put air in my tires when I returned but 3 of my tires will not take air. I can let air out but cannot put any air in. I have used two different air compressors so that is not the problem.
Are the tire valves stuck somehow from non use and sitting outside under a car port? Any thoughts ? I cannot figure this out!!
Old Apr 3, 2018 | 07:32 PM
ART T's Avatar
ART T
Try a different air chuck.
Old Apr 4, 2018 | 01:45 AM
HOXXOH's Avatar
HOXXOH
I have one of three that won't consistently work on all cars with TPS.
Old Apr 7, 2018 | 07:59 AM
blueflame1954
Thanks have tried two different air chucks
iNeither works 🙄
Old Apr 7, 2018 | 10:03 AM
reasonable suspicion's Avatar
It's possible the last tire place installed brass valve cores instead of nickel plated...... grab some nickel ones, and a tool and swap them, you will only lose a pound or two of you're quick. Then they should be ok
Old Apr 7, 2018 | 08:08 PM
blueflame1954
Default C6 Tire Pressure Valves
[B][B]
[B] Thanks for the info. I'll check it out when it warms up. Lol : )
I think they are all nickel but not real sure, ]
To C6 Tire Pressure Valve
