Question on waterpump bolts..
Old Apr 6, 2018 | 11:33 AM
WW7's Avatar
WW7
Default Question on waterpump bolts..
Do the bolts go into the water jacket or are the holes blind on a LS2.waterpump install?...WW
Old Apr 6, 2018 | 03:18 PM
CI GS's Avatar
CI GS
Not sure about the LS2 blocks, but I’m pretty certain that they are blind on the LS3 block. Come to think of it, they must be, oherwise you would need to put sealant on the thread to keep them from leaking around the bolt heads, no? The easy way to check is to pull one bolt out and see if any coolant leaks out.
Old Apr 6, 2018 | 08:57 PM
WW7's Avatar
WW7
I installed the pump today, the bolt holes on an LS2 are blind..No need to use sealent to stop leaking. 2 hour job...WW
To Question on waterpump bolts..
