HVAC issue
Old Apr 6, 2018 | 11:32 PM
msd127's Avatar
msd127
Default HVAC issue
Was driving my C6 427 today and needed to run the heat. The driver side heated up fine but the passenger side blew cold air. I tried adjusting the ***** and settings but no luck. Does any one know what part(s) will need to be replaced. Before I take it to the stealer for diagnosis, thought I would check here first.
Old Apr 7, 2018 | 02:14 PM
RicK T's Avatar
RicK T
Hopefully the dealer will be able to diagnose based on OBD codes found.
It is likely to involve the mode door actuator(s) or the door(s) themselves. An actuator isn't a big deal but anything beyond that means the dash has to be removed. In past years, I haven't seen any recent reports here, the typical cost has been north of $1500 for that worst case scenario.
Please let us know what happens and good luck for a minor repair.
Old Apr 7, 2018 | 03:07 PM
msd127's Avatar
msd127
Thanks Rick i think you are likely bang on, I will keep all posted once I get a diagnose.
Old Apr 8, 2018 | 02:01 PM
jsucraig's Avatar
jsucraig
I would try disconnecting the battery for 30 seconds and then reconnecting. Anytime my HVAC starts acting up this fixes it (2013 Grand Sport). **Don't forget to re-index your windows after reconnecting the battery.
Old Apr 8, 2018 | 04:00 PM
msd127's Avatar
msd127
Default Hvac
Thanks will try that.
Old Apr 17, 2018 | 11:28 PM
JABCAT's Avatar
JABCAT
Sometimes I have to cycle mine through the different vents, i.e. defrost, lower vents, upper vents, etc. before it switches over to the temp at which I have it set.
Old Apr 18, 2018 | 01:12 AM
msd127's Avatar
msd127
Default Ttt
Thanks this is good advice. We just had 2 inches of snow today. Once I get the car back on the road again I will try some of these helpful tips. Thanks to all
Old Apr 27, 2018 | 11:36 AM
msd127's Avatar
msd127
Default Ttt
Just an FYI once the weather warmed up the issue seemed to sort itself out 🙂. These cars don’t like cold weather.
To HVAC issue
