engine drag control active
Old Apr 22, 2018 | 10:51 AM
CRMvettezr1's Avatar
CRMvettezr1
Default engine drag control active
dealer re-flashed BCM (body control module) due to key new fob and memory option settings. Thanks
Old Apr 22, 2018 | 08:42 PM
RicK T's Avatar
RicK T
Ride height adjustments do not affect Drag Control.
Good explanations in this discussion, especially post 4 by talon90:
https://www.corvetteforum.com/forums...post1570345909
Old Apr 23, 2018 | 08:46 AM
irok's Avatar
irok
Originally Posted by CRMvettezr1
Gentlemen, raised my front ride height yesterday 1/2 inch and shortly after leaving dealership, got on the throttle and on decel received a engine drag control message. This is second time of raising ride height because it was set way to low previously. I do have Michelin tires up front and Nitto DR on rear (stock size) and never had a problem before. Question is can raising the front ride height cause this message? Should also note that dealer re-flashed BCM (body control module) due to key new fob and memory option settings problem. Thanks
large difference in tire height front versus rear will also cause this message to display.
To engine drag control active
