Base C6 Vs Z51 Brakes
Again, same size and shape, different compounds.
Shipping (even overnight shipping) isn't horrible for brake pad sets. IMO, it's better to get the right stuff than to get cheap trash that's available now.
You're welcome.
Next set of brake pads I buy I'll buy the carbotecj 1521
If you can get the Akebono Performance pads from that same source, those are significantly better pads in terms of grip and "stopping force." Fronts are ASP731, rears are ASP732. They aren't up to what the Carbotechs can do, but they are probably "good enough" for most street and spirited rural (twisties) driving.
1) So I'll invest in some good pads and replace the brake fluid from 2008
2) I am still debating if I should switch to the J55 rotors/brackets in the front. Reading from all the comments, it seems that wouldn't be the best money spent. So going back to square one - will get some "good" pads and fluid changeseems like a common consensus here.
3) I'll be trading my OEM calipers for the Red Powder-Coated calipers soon (for looks obviously). Since the seller will be getting my Base calipers as core, he has given me the option of changing to the J55 (Z51) front calipers for no extra charge - I thought JL9 & J55 setups use the same caliper up front - if that's true, he's just pulling my leg then
. Either way, I'll have to buy the larger brackets ($140 extra) and J55 rotors ($150) to complete the setup. Now, the Question is - should I change over to J55 setup in the front ($300 extra with Base setup in the rear) OR stay with Base calipers, rotors, pads all around?
Thanks again!
Are all rear brake pads the same size and fit?
If not what do I need to look for at the local advance auto part store..
They don't carry a lot of stock and I don't have time to ship etc..
F: 731
R: 732
Thanks again!
If you're getting some pulsating, you can either get your current rotors turned (about $15 each at Autozone etc) or buy new rotors. You can reduce or eliminate the cause of pulsating by not holding the brakes on after hard use without moving the car slightly. Move the car a foot or two every 15-20 seconds to allow the rotors to cool more evenly. Without moving, overheated rotors can't cool under the pads and that creates hard spots and can crack rotors.
As far as painting calipers is concerned, the $5 rattle can paint works well. While rotors can get pretty hot, calipers don't get hot enough to require any special paint. Because you'll be taking them off anyway, it'll only take an hour to clean and spray all four. I do a touchup every pad change.
For daily driving, I got 60k miles out of the original J55 pads and rotors with no issues, but the pads were nearly done. I changed to DBA4000 rotors and Carbotech 1521 pads and have been on those for the last 70k miles. The Carbotech 1521 pads are much more gentle on the rotors, both from a dust and abrasive standpoint, but they do have noticeably less bite, especially the initial bite. That said, I've not been ever able to not stop when I've needed to. They definitely stop well. I am due for a brake job again and while the Carbotechs are on my short list (as well as the OEM pads) there are a lot of options out there. PowerStop Z26 and Z23 have been getting great feedback and at half the cost of the OEM or Carbotech pads, it is tough to ignore. Hawks, Akebono, Performance Friction, etc. all make great pads but you will have to decide ultimately if lower dust is worth the trade off of less stopping power, especially after your brakes get heated up. For a daily driver, ceramic pads are a no brainer. They do the job fine. If you want to canyon carve and need reliable brakes all of the time, I would at the very least go with OEMs or some other semi-metallic.
So price won't be a big factor in the comparison of these two, it will be the overall performance, lifespan, dust, quietness and such features.
So price won't be a big factor in the comparison of these two, it will be the overall performance, lifespan, dust, quietness and such features.Yeah, for the price Z26 looks like a great option.
I'll repeat it.
You need to either change all the rotors and matching brackets to the J55 size or stick with the JL9 size.
Mixing incompatible rotor sizes and/or different front/rear pads causes problems you don't want, unless you have a specific need for the results. But if you do have a need, you wouldn't be asking those questions on this forum.
I'm strictly talking about the rear only. My car is a Z51 equipped car. I will be doing a 15inch rear wheel conversion.
I've been told and have read that the calipers are the same. The brackets and rotors are different though, is this true for the rear?
Will z51 calipers/rotors work with a 15 inch conversion
Last edited by KNSBrakes; May 8, 2018 at 01:48 PM. Reason: Error - please disregard
