Bolt On Modifications for C6
Old May 1, 2018 | 10:28 PM
rootine4's Avatar
rootine4
Default Bolt On Modifications for C6
I am looking for people's advice on mods for my 13 GS Coupe.
When I put headers (and true dual exhaust) on my C3 I was very pleased with the performance results. However, the extra heat burned through a spark plug wire.
I am thinking of adding headers to my C6 and maybe cold air intake. If I am going to do headers I likely will want to get shielded wiring. If I am going to do that should I install a performance ignition system, too?
Thoughts on headers?
Thanks in advance.
Old May 1, 2018 | 10:36 PM
CJ Willys's Avatar
CJ Willys
I've had un-coated long-tube headers for 3 years. I did insulated my starter, but I've checked good and have no wires too close to tubes. No problems. I had a cold air intake but then installed an A&A supercharger. Still have stock ignition. Got it performance tuned and dyno'd 555 hp. I also installed 2 oil coolers because oil temps were hitting +275F at the track.
Old May 2, 2018 | 11:23 AM
jaredtxrx's Avatar
jaredtxrx
Don't waste your money on an intake for an LS3 until you're doing heads/cams. The OEM intake on the LS3/LS7 is quite good.
Old May 2, 2018 | 01:59 PM
farmington's Avatar
farmington
no need for ignition updates.
these motors do love a camshaft update when you're ready, if you have an A6 a Yank 3600 converter is a good step too
Old May 2, 2018 | 06:55 PM
jaybee924's Avatar
jaybee924
How much are you wanting to spend, on the headers and mid-pipe? I have some of what your looking for sale. If your interested PM me
Old May 8, 2018 | 01:02 PM
Ragtop 99's Avatar
Ragtop 99
center console heat is an issue with these cars. I'd coat the headers, and add an insulated tunnel plate when installing the headers.
A tune to go with the headers would be a good compliment. Tune + headers will give you a boost you can feel.
To Bolt On Modifications for C6
