Cruse Control
Old May 4, 2018 | 10:14 AM
Kingstonontario's Avatar
Kingstonontario
Default Cruse Control
Just bought this 2013 Corvette. The first time I went to use the cruse control, it didn't work. When I got home I checked the fuse box. There was no fuse in the spot for the cruse control, so I put one in (3 Amp) and it still does't work. Any ideas ?
Old May 4, 2018 | 12:00 PM
Kenny94945's Avatar
Kenny94945
Look to the switch at the brake pedal.
Good luck.
Old May 4, 2018 | 06:37 PM
Icecap's Avatar
Icecap
I had an issue with my cruise control last year when it quit working for no apparent reason. I also checked the fuse and found that it was OK.
I asked for help on the forum and someone suggested that I disconnect the battery for a while then hook it up again and try it. I unhooked the battery and my wife and I went out for dinner. I reconnected it when we came home and took the car for a test drive and it worked again.
To Cruse Control
