cant get in
Old May 8, 2018 | 02:05 PM
latenightlarry's Avatar
latenightlarry
Default cant get in
hi guys 2005 vert. with not enough power to open door. pulled cable but onle opens a little . any ideas?
Old May 9, 2018 | 10:22 PM
mikeCsix's Avatar
mikeCsix
Use the key?
Old May 10, 2018 | 10:42 AM
itomh's Avatar
itomh
Originally Posted by mikeCsix
Use the key?
This is a vert, that will get you in trunk but not car. Just jack up the front of car and hook the positive battery charger cable to the power terminal on the starter and the negative cable clamp to the frame. Then press the unlock button on your fob.
Old May 10, 2018 | 11:37 AM
EVRose's Avatar
EVRose
Use the key?
He did use the key. That's how he was able to pull the door release cable.
If you can get in the trunk you can get in the car. That's where the door release cable is.
I think he just has to pull harder on the door when the latch releases so the window will clear the weather strip on the roof.
Old May 10, 2018 | 12:01 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Also might help to have a second person pull on the door while he pulls the release.
Old May 10, 2018 | 10:16 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
hold the door button down while pulling on the cable longer
To cant get in
