service traction control light,reduced engine power
Old May 14, 2018 | 10:59 AM
NightWolff51's Avatar
NightWolff51
1st Gear
Default service traction control light,reduced engine power
wheni was driving i came up to a stop sign,felt alittle vibration in the car and the engine check light came on and the traction control light came on and on the DIC it read reduced engine power and service traction system ,what would cause this
Old May 14, 2018 | 12:22 PM
xBoostx's Avatar
xBoostx
Have you done work in the car lately is so check all plugs, connectors all must be pushed in all the way, grounds.
If not check see what trouble codes you find.
Check battery life.
